Old 05-07-2019, 05:55 AM
Default Hairba11’s hc4 tonka big tow
So I picked up an hc4 off a buddy.
But I’m not a super fan of the m105 trailer bed bobber, but I remember a tow company around here that had a off road recovery wrecker so I started looking for tow trucks.
I ended up winning a lot of two tonkas in rough shape.
I used the bed off one, and the booms off the other.
Have I mentioned how much I love the shot blaster at work?
And a little rustoleum apple red to match the cab.
Speaking of the cab, I yanked the dual stacks off the back of it and whipped up my own from perf metal and 5/16 brake tube.
Then I made an air cleaner mushroom from a 3/8” carriage bolt.
Looks much better.
Old 05-07-2019, 05:46 PM
So half the tire is sticking out. And the space between the top of the tire and the wheel well looks goofy.
Well? The bed fits in the bandsaw.
Enter bed number two.
A little shot blaster action and separation of the two pieces to get the full floor plus about 9/16 (14mm) more on each side connected to the red sides. Little welder action connects all the pieces.
New and improved wide bed.
The wider bed now straddling the fuel tanks instead of resting on top. Shorter bed mounts will lower the wheel well about 1/2 (13mm) and leave the same gap as the front fender height.
Old 05-08-2019, 06:36 AM
Got the rear notched to clear the bumperettes.
Whipped up the convoy lights from 10mm led flashers (yellow) and 1/4 inch brake line.
The height is right, the tires are covered, this thing looks awesome.
Just need to wire up the lights and install the boom winches when they show up.
Old 05-08-2019, 06:08 PM
looks good
Old 05-08-2019, 06:17 PM
I wholeheartedly agree!
Old 05-09-2019, 11:07 AM
Thanks guys.
So I wired up lights this morning.
The flashers look awesome.
One marker doesn’t work.
And some idiot put reds in the headlights instead of whites.
And at 12.5 lbs it’s listing to starboard
Old 05-09-2019, 06:59 PM
Red makes it go faster... so fast that she's leaning into corners standing still
Old 05-11-2019, 05:06 PM
To combat the sag I started today with the standard lawnmower recoil spring.
I made a replacement main leaf, then added a second main leaf with a double eye.
It’s flatter but stiffer. The ride height isn’t changed.
I also got started on some bed boxes for the chain and ropes and tools.
I even got it out and drove it around a little. This thing is awesome!
Old 05-15-2019, 07:57 PM
chewyscool's Avatar
chewyscool chewyscool is offline
LA4x4
Member Number: 14545
Hey thats a nice truck!
Awesome work.
Old 05-15-2019, 10:43 PM
I'm digging it, except the red headlights. Might need some lettering or graphics on the sides
Planning to make the winches work?
Old 05-19-2019, 05:25 AM
I’ve been tossing around the name of Dirty Hooker
Yeah smaller winches are on order as are some more accessories
Speaking of:
The small winch fits inside the boom so I ordered one that looked like it. Turns out it’s 8th scale.
So it now lives on the front and two smaller winches are on order for the rear.
Then I threw some round stock in the lathe
And made some oxy-acetylene bottles for the bed.
Splash
Old 05-29-2019, 08:16 AM
Noobsk8r Noobsk8r is offline
Member Number: 19523
Just plain awesome. Keep it going bud I would like to see it recovering something when your done?
Old 05-29-2019, 10:26 PM
sig p232's Avatar
sig p232 sig p232 is offline
I am the Scale 4x4 R/C Grand PooBah!
Member Number: 11
Awesome work!!
Nate
Old 05-31-2019, 03:11 AM
Still waiting on stuff to come in. Got some scale details coming in also.
Old 06-09-2019, 07:42 PM
Winches came in, got them installed on the booms. Took it for another little drive.
