View Poll Results: Where and when should the LSTR meet?
Do the LSTR on the last Sunday and the aLmoSTR on the second Sunday 13 81.25%
Do one month London, next month Away 3 18.75%
Do them on the same day, and let people chose which to go to 0 0%
Voters: 16. You may not vote on this poll
Closed Thread
Old 03-01-2010, 08:30 AM
simon.110's Avatar
simon.110 simon.110 is offline
Member Number: 10886
this too
  #707
Old 03-01-2010, 12:51 PM
grahamg's Avatar
grahamg grahamg is offline
LSTR scale rules OK
Member Number: 3315
x2 Excellent videos Julius
Let the Scale 4X4's rule LSTR
  #708
Old 03-01-2010, 12:53 PM
Sao Sao is offline
Member Number: 2026
Nice vids julius. Shame I had to go home with a smoking esc, thats the second rooster to go up in smoke in as many months, going to try a tekin fxr next and if that fails I am going to put in an old tamiya wiper blade and resistor set up
Flickr
  #709
Old 03-01-2010, 01:03 PM
elliot330 elliot330 is offline
Member Number: 10691
Tekin all the way but you need to order a hotwire to get the full potential.
I remember them tamiya ones, I always had the urge to touch the heat shield, even though it cleary stated "hot, do not touch" !
  #710
Old 03-01-2010, 02:24 PM
Paul0088's Avatar
Paul0088 Paul0088 is offline
There is no spoon
Member Number: 7613
what do you do with the hot wire? cut some foam core wings??
  #711
Old 03-01-2010, 02:30 PM
Dready's Avatar
Dready Dready is offline
Member Number: 2380
+1 For Tekin FXR never misses a Beat and i run Two Motors off mine
  #712
Old 03-02-2010, 04:22 AM
jai_landrover jai_landrover is offline
Member Number: 7969
cool vids, well done guys.
Just recieved my 65t motor from the states all in inc delivery was 9.50 or $16.82 from TGN industries epackaged as RC4WD. Very happy now i need to try it!
  #713
Old 03-02-2010, 05:15 AM
Sao Sao is offline
Member Number: 2026
You certainly could have cut foam wing cores with my Novak wires on Sunday!
It was hot enough to melt the solder on the battery and deans connectors!
I got my FXR from Apex models but they didn't list the hotwire and TBH for what I need for trailing I don't really need to alter the programming much. But if I do I am sure someone will be really helpful and bring their hotwire to a meet
I used to use a Tekin 411 back in my buggy racing days, good esc's I still have one kicking about somewhere
Ah yes the good old ceramic resistor that used to shatter if it got knocked, I saved you the trouble of touching it, they did get fricking hot
Flickr
  #714
Old 03-02-2010, 11:07 AM
Dready's Avatar
Member Number: 2380
The Fxr is perfectly fine for Scalers without the Hotwire.
You can adjust plenty for what we do.
  #715
Old 03-02-2010, 03:10 PM
No problem at all, when it arrives here that is!
  #716
Old 03-02-2010, 03:16 PM
Agreed, it works straight out of the box, the only thing you can't access is the throttle curves, which I think would be good for the slow scale speeds we do... but then again, if you have expo function on the TX then it doesn't matter anyway.
The other thing the Hotwire allows (not cutting foam wings ) is updating the software - my FXR was dated August 09 on the box, I believe there have been few software updates since then?
Once I receive it and get it work, I will bring it to the meet... and you can play all you like
  #717
Old 03-02-2010, 03:18 PM
Haven't seen them vids before - good find. They look good, but they also look a little top heavy for the terrain we normally run on.
  #718
Old 03-02-2010, 03:20 PM
Originally Posted by LondonF350 View Post
Don't forget that you need two 'passthrough' axles for an 8x8, like those found on the back of the Tamiya big rigs (drive in one side and out again on the other). I believe tlt/f350 axles can be modded to be passthrough, there is probably a 'how to' somewhere.
Yep, I posted an axle question in the multiaxle part of the forum and someone kindly replied and explain, seems easy enough, just need a few truck parts.
  #719
Old 03-02-2010, 03:58 PM
Dready's Avatar
Member Number: 2380
Drop UK Andy a line.
He had a guy in the states knock him up a 6x6 Chassis very reasonable from what i can remember.
He Doesn't bite
  #720
Old 03-03-2010, 03:09 AM
Member Number: 7969
does anyone on here make their own chassis?
Seems alot of people buy a chassis and put their axles on them. I've just done a very rough drawing for a scale ALRC comp motor will try and get the tube today if anyone knows of any cheap supplies of 1meter lengths of 5mm external tubing with a 2.5 or 3mm internal hole let me know. Will start a thread once building starts. Curious why people buy chassis' thats all.
Jai
Closed Thread
