Old 06-17-2010, 02:57 PM
ThomasR's Avatar
ThomasR ThomasR is offline
Member Number: 3583
Well, right now it weight 2,1 kg (incl. battery pack). With 4 shocks and 4 coils the but come up easy. You can see it on the video. I dont know if two coils will be enough to do same. Problem is, the dual shocks do not really have damping function like other oil filled shocks with larger body. So they rear feels a bit bouncy and I am also afraid that, with two coils only the but will hit the ground to easely.
  #107
Old 06-17-2010, 03:12 PM
Waterboy's Avatar
Waterboy Waterboy is offline
Member Number: 10658
B/S/T Feedback: (9)
Ah, ok. I think having 2 shocks with springs and 2 shocks without springs would be good for the end.
W@T3R8oY wUz H3R3! Well, im Broke MoFo #89!! Eat that Lauer!!
Im suffering from RC addiction. Oh it hurts so good.
Old 06-17-2010, 03:30 PM
ThomasR's Avatar
Member Number: 3583
At last I hope so. If not, I might try to use 4 coils and some small amount of sticky grease inside of two shocks. Maybe this will provide enough friction to do some kind of damping.
Old 06-19-2010, 09:41 AM
Banana's Avatar
Banana Banana is offline
Member Number: 9159
Originally Posted by ThomasR View Post
Got another thing done tonight...rear shock towers. Now she can stand on her own feet
As I have been asked to make a video, here it is. It is just a very simple video showing how the suspension works. Nothing special.
http://www.youtube.com/watch?v=QTpg6GnpoU4
oh my God
you are a genius
this Sandrail is very beautiful...
some questions:
wich material you use to braze?
is it castolin?
and...can I copy You?
ovviously not, but I'm very impressed by your work
This Buggy is very Scale looking
i wish I will become able like you to build...
Old 06-19-2010, 12:27 PM
ThomasR's Avatar
Member Number: 3583
Thanks alot Banana for the compliment but, I am really no genius. I am just an average model builder with average skills of modeling.
I am not brazing, I am welding. I use a standard electric welding device with 2mm electrode. Similar like that one:
I'd like to be able to braze because the seams are nicer when brazing. But I do not know much about brazing, so I am welding. At last I know a little about it. I have some welding experience since I welded alot on a 79' Chevy Blazer which I restored 2007 and I made a roofrack for my Jeep Cherokee two years ago.
Sure you can copy it, why not. I did nothing special. Buy yourself a welding device and start testing. You'll see it is not so difficult. But I am happy you like my work.
I hope it will really looking quite scale. Actually this is what I want.
By the way. Within July/August I'll get my rack and pinion steering built. Hope it will look good.
Old 06-19-2010, 12:34 PM
for your shock issue, you could experiment with different springs and shock oil wieghts.
if your ''too bouncy'' a softer spring in at least one shock in the rear would help out greatly.
Old 06-19-2010, 12:41 PM
ThomasR's Avatar
Member Number: 3583
good point with the softer spring, I'll give it a try. Also I'll try to use a #600 tamiya shock oil and see if this prevent a little from bouncing.
Old 06-19-2010, 01:27 PM
ThomasR's Avatar
Member Number: 3583
Ha! It works. I just used tamiya #700 shock oil and filled all four shocks. I always thought these shocks cannot be filled with oil, but I was wrong. They can be filled and they work good. Only thing, they cannot be filled until the top, they need some 7mm oil free room to the top. Now the rear is not bouncy any more.
Old 06-19-2010, 04:44 PM
ThomasR's Avatar
Member Number: 3583
All right, I have been welding once again. This time the front end got some additional support. And some comparison pictures from the real thing.
Old 06-19-2010, 06:56 PM
caprinut's Avatar
caprinut caprinut is offline
Member Number: 448
Awesome mister
R.I.P Ole (8th Oct 2012)
Old 06-20-2010, 02:03 AM
lemecanodejante's Avatar
Scale is good!
Member Number: 1144
agree!!
Old 06-20-2010, 07:44 AM
Banana's Avatar
Member Number: 9159
oh, Ok
I have an electric welder, but I must Find small electrodes...mine are now 4mm :-(
i'm Able with Brazing, about 3-4months it's very Easy with Castolin Sticks ;-)
you can also use Associated RC18T springs Blue on the top of the shocks...they are very soft ;-)
Old 06-20-2010, 09:11 AM
ThomasR's Avatar
Member Number: 3583
What equipment are you using for brazing? Could you make a picture of it?
For welding, 2mm rods are more than enough.
I solved the matter with the bouncy rear end. I used a Tamiya #700 shock oil in all 4 shocks, that works great.
Old 06-20-2010, 09:20 AM
ThomasR's Avatar
Member Number: 3583
Welded a front cross member with shock stay and made some progress on the V8 engine. Now missing only motor mounts and custom headers. Motor fits very tight into the engine compartment.
Old 06-20-2010, 10:44 AM
Banana's Avatar
Member Number: 9159
I use a torch with two separated acetylene and oxygen cylinders
I'ts an expensive equipment, but my father is a plumber (in Italian we call it "Idraulico", but I don't know the exactly translation ) and He uses them for working
there are more cheaper torches, like Castolin ones
for brazing there are a lot of Castolin sticks type, from smaller to bigger ;-)
Sorry for my english ...i wish you can understand...
