Old 06-21-2014, 02:05 PM
Arcocustom's Avatar
Member Number: 2344
ARCO CUSTOM PERFORMANCE
  #122
Old 06-23-2014, 07:52 PM
Arcocustom's Avatar
Member Number: 2344
Box stock Kyosho TOMAHAWK (#3065)
Team Blue Groove body
TAMIYA PS-5 Black, PS-16 Metallic Blue, PS-36 Translucent Silver & PS-13 Gold
Marwan SC-81 Decal Set
Thanks for taking a look. - Arco
Old 06-24-2014, 01:44 AM
Hcp22's Avatar
Hcp22 Hcp22 is offline
Member Number: 16219
Looking Grate
Cheers Lars
Old 06-24-2014, 03:14 PM
Arcocustom's Avatar
Member Number: 2344
Default 2014 Kyosho - Turbo Scorpion Off-road Racer
The 10th build has a lot going on. Hope is, that I can keep track of it all...
Atilla Bokodi (Germany)
  • Patented - Selective Laser Sintering (SLS) processed, repro Kyosho Scorpion Radio Box
COX MODELS
  • CB-124 Linkage Boot
  • RS-13 Gear Box
  • SC-4 Lower Arm Set
  • SC-6 Upright Set
  • SC-7 Knuckle Arms
  • SC-9 Servo Saver Mount
  • SC-17 Swing Shaft
  • SC-18 Rear Wheel Shaft
  • SC-21 Rear Guard Set
  • SC-30 Body Support
  • SC-36 Gear Base Cover
  • SC-41 Servo Saver
  • SC-42 Rear Suspension Arms
  • SC-45 Gear Box Seal
  • SC-56 Differential Gear Set
  • SC-61 Gear Set
  • SC-64 Front Bumper
  • SC-65 Rear Wheel Shaft Bearing
  • SC-78 Roll Bar
  • SC-85 Rear Shock (Special)
  • SC-87 Upper Arm Assembly
  • SC-89 Tie Rods
  • SC-95 Steering Rod
  • SC-97 Roll Cage
  • SC-100 Wing Set
  • SC-102 Gear Box Cover & Fitting Plate
CRP
  • 1701 Cox Trailing Arm Pivot
  • 1707 Arm Shaft
  • 1711 Adj. Coil-Over Collars - Optima (set of 4) also fits Assault, Turbo Scorpion, and Ultima
  • 4115 Wheel Adapter - Kyosho, Cox - designed to allow Tamiya tires & wheels on the front of a Kyosho car
  • 5140F FRONT WHEEL BOLT SET (20 Piece Stainless hardware kit) 10 - 2 x 8mm Socket head cap screws & 10 - 2mm Hex nuts
http://www.rcchopshop.com/team_crp_rc_car_parts.html
Dwayne’s CNC Machine : (dwyz250)
  • 10mm Extended Front Shock Mounts
  • Beveled & Countersunk Gearbox Mount
  • Rear CRP-Style Hubs for Tamiya SRB Wheels
DuBro
  • 2285 3x6mm Countersunk Machine Screws (4)
  • 2287 3x10mm Countersunk Machine Screws (4)
  • 2290 3x16mm Countersunk Machine Screws (4)
Kyosho Corporation
  • CB-88 Shocks
  • CB-88A Shock Springs
  • 1988 LeMans Speed 480T (19T, ball bearings, 26,500rpm)
  • PI-3 (C) Block Parts (Black Plastic) - Pegasus & Icarus, (Cox Bandido)
MIP
  • WW-100 Wide Aluminum Rims for Holiday Buggy
Pargu 2000 : (pmg828)
  • ms0051 kyosho scorpion tomahawk assault chassis bar
Pro-Line
  • 200-F Rough Rider Replacement Front wheels
RCH
  • 363 COX/KYOSHO Rear Shock Adapter
  • 1101C COX/KYOSHO Rear Suspension Plate
  • 1.75 Polished Aluminum Front Wheel Halves
Tamkyo Repro Decals : (tamkyo-reprodecals)
  • REPRO Turbo Scorpion Decals Stickers Set
Tamiya
  • 5153 Holiday Buggy Spare Tire "REAR" with Wheel
  • 53009 RC 1150 Bearing Set 4pc
  • 19805108 Tamiya Buggy Champ Rough Rider Fast Attack Vehicle Front Tire
Old 06-25-2014, 11:56 PM
Arcocustom's Avatar
Member Number: 2344
... nothing to see here.
Old 06-26-2014, 12:31 AM
Arcocustom's Avatar
Member Number: 2344
Originally Posted by Hcp22 View Post
Looking Grate
@Hcp22
Thanks for checking out the stuff.
So, the wheels and tires are bolted on and the new body is trimmed and fitted as well.
Turbo Scorpion rear shocks with alloy CRP collars are bolted on out front and a new
lower arm set, upper arm assembly, tie rods, steering rod, servo, linkage set,
servo saver, wing mount, roll bar, & rear guard set were also installed.
First Mod: drilled 3mm holes like the stock mounts in the the extended front shock mounts and installed an "RCH-style" shock tower brace.
Second Mod: made a custom wing mount.
Thank You for taking a look. - Arco
Old 06-26-2014, 02:57 AM
Hcp22's Avatar
I like that you use all those hop-ups!
Those RCH support brackets also came in carbon fiber.
Cheers Lars
Old 06-27-2014, 03:39 AM
danrkelly danrkelly is offline
Dan_in_UK
Member Number: 21177
Great work, lovely buggies, interesting parts...cheers from Dan in London UK.
Old 07-06-2014, 11:17 AM
Arcocustom's Avatar
Member Number: 2344
@ danrkelly & @ Hcp22
Thanks fellas. Spent the 4th tinkering with the buggies and got some more mods to share.
REAR SHOCKS
Trinity 30wt silicone fluid.
FRONT SHOCKS
Trinity 10wt silicone fluid.
Old 07-06-2014, 11:20 AM
Arcocustom's Avatar
Member Number: 2344
Cox part# SC-12 Front Shock Stay(1982 - Sidewinder/Scorpion/Beetle)
Kyosho - Parts pack #SC-012 (Scorpion) & Part #AB-32 (Assault) Front Shock Stay
Thanks for taking a look. - Acro
Old 07-06-2014, 02:55 PM
marzo marzo is online now
Member Number: 20606
Old 07-09-2014, 11:42 AM
Arcocustom's Avatar
Member Number: 2344
Default 1982 Cox Scorpion shock upgrade
@ marzo
Well, I just checked and supposedly there is one on the way to my house by sometime today.
Got it @ RPP this past Sunday. http://www.rpphobby.com/product_p/kyo30613b.htm
$219.00 w/free shipping + a free 7.2 battery @ checkout. We shall see. Tower will have some in stock soon as well.
2014 Scorpion Parts List http://www.kyosho.com/jpn/support/in..._2014_spop.pdf
Some real nice option parts on there... real nice... *FOR JAPANEESE MARKET ONLY*
1982
Cox Scorpion
Old 07-12-2014, 11:02 AM
sf2000xj's Avatar
sf2000xj sf2000xj is offline
Member Number: 4312
Hey Arco is it normal for the rear suspension to bind slightly? I picked up a scorpion rerelease and started putting it together last night, when I got the rear suspension on I noticed it hangs up in the middle of cycling the arms up and down. I haven't installed the shocks yet. If I take out the dogbone the arms move freely but with the dogbones installed is when I get the binding. I didn't notice where the parts were left and right I even swapped them and it still happens. Any thoughts?
Old 07-14-2014, 06:05 PM
Arcocustom's Avatar
Member Number: 2344
Default I think an alignment may be in order.
@sf2000xj
I have heard mention of the issue you describe from a few others. IDK why the arms are binding other than the way it may be bolted together at the pivot. I have not built mine yet. It is still sealed.
My guess is that this pivot is a hinge and the hinge is binding. Sometime on the old cars there is some play and there is an optimal angle for this pivot. Maybe it will disappear after it is broken in but I would put all the pieces together with the bolts slightly loose and attempt to set that hinge just right.
Hope this helps. Best of luck. - Arco
Old 07-14-2014, 08:39 PM
sf2000xj's Avatar
Member Number: 4312
@sf2000xj
Thanks for the reply, I've narrowed it down to the driveline, the dog bones are just a smidgen to long. Actually I think the drive cups on the diff should have been machined out just a little more. It only happens with the shafts installed. For the most part the shock springs can overcome this and rebound back but sometimes it sticks. I put it all together and will run it I'm sure after a while they will wear in and it will go away. The only problem I have now is I want to buy two more and build a Tomahawk and a Beetle, lol.
