Old 09-28-2010, 12:21 PM
mangus7175's Avatar
mangus7175 mangus7175 is offline
I R NOOB
Member Number: 9565
Simply amazing...
  #92
Old 09-28-2010, 12:23 PM
gaz gaz is offline
Member Number: 11477
fantastic attention to detail.....
cant wait to se it finished!!
Old 09-28-2010, 01:01 PM
jan_m's Avatar
jan_m jan_m is offline
too many projects, to many ideas
Member Number: 6746
Great build, love your eye for detail. Very nice work.
gtrz
trying to write English
Old 09-28-2010, 01:04 PM
Mg-rover1's Avatar
Mg-rover1 Mg-rover1 is offline
D90/Discovery II/LR3
Member Number: 10454
You nailed that rack!! Awesome!
Old 10-01-2010, 07:09 AM
nevets's Avatar
nevets nevets is offline
Member Number: 12577
***FRONT BUMPER UPDATE***
I have bitten the bullet and started on the front bumper again. This time I am using thinner 26 gauge sheet metal. I am just using straight tin snips to cut. It is/was not ideal but it got the job done.
Pics:
I used adhesive paper in my printer to print out the template. You can see it is slowly getting burned off as I weld.
All the components are welded together now as you can see in the photo above. Next to start on mounting brackets.
Not photo'd yet, I have cut out the top for the winch and also welded in the the winch tray. I have placed it onto the chassis and set the body and it all works out well.
The next part will be the bull bar, cut out for fairlead, and holes for recovery points. Not to mention lots of filing and clean-up. I hope to have this thing wrapped up by the end of the weekend. Then it will be onto the rear bumper.
Cheers,
-Steven
Old 10-01-2010, 07:14 AM
nevets's Avatar
here again is the inspiration:
Old 10-01-2010, 07:20 AM
ford92's Avatar
ford92 ford92 is offline
if you don't use it, ya won't break it
Member Number: 2177
nice fabrication on the winch bumper looks good
Old 10-01-2010, 07:35 AM
brazwewn's Avatar
brazwewn brazwewn is offline
1% Inspiration - 99% Perspiration
Member Number: 11667
Nice work, this is giving me some ideas for my Land Rover!
Wes
Old 10-03-2010, 09:03 PM
nevets's Avatar
So, I scrapped the bumper. I was off on a measurement and when I started adding the tubing, it turned out wrong. So I started on 2.0 and it was actually going better than the original. Unfortunately I ran out of solder and I wont have my order coming in til sometime this week.
However, I did get a nice little package from Stefan at Scale Offroad.
I got 8 large lights to be used as Hella 4000 off road lights, 1 winch hook, 2 shackles to be mounted on the front bumper like the swivel D-rings on my Safari Gard bumper. I also got 8 straps (in real life I strap things onto the roof rack, not bungee) a new winch line (will try to dye it green like my 1:1) and a sweet snatch block.
A couple weeks ago I had received my roof rack LED lights from Bill at Bill's Custom RC Lighting. So, since I now have my housings, it was time to make these Hellas shine.
The housings are attached to the roof rack light tabs using a 1/8" bit of brass tube as a sleeve with a screw and nut going through. All the wiring travels under the rack to the tote on the back of the rack where it is powered by a 9V battery.
Above you can see the on/off switch for the lights
And Finally below, how they shine in the dark.
Cheers,
-Steven
Old 10-03-2010, 09:07 PM
pardonmyn00b's Avatar
I ain't not a dorkus
Member Number: 8206
That roof rack is baddddass! This is one killer build. Keep up the great work.
Old 10-03-2010, 09:41 PM
turkman's Avatar
turkman turkman is offline
Member Number: 6518
You possess some fantastic fab skills! That roofrack is a complete work of art!
I can't wait to see where you go with this.
Old 10-04-2010, 01:18 PM
stburr91's Avatar
stburr91 stburr91 is offline
Member Number: 3985
The install on the lights is super clean, great job.
I agree with turkman, the rack is a work of art.
Old 10-04-2010, 02:15 PM
nevets's Avatar
Thanks for the compliments fellas, I appreciate them. I do not know if I have mentioned it, but this is my first scale build and I'm enjoying it thoroughly. (Cannot say the same for the wife's enthusiasm)
I can only do this because of the tips & tricks I have learned from this community.
Just think, I do not think I'm quite 1/2 finished with this build.
Well, thanks again!
Old 10-04-2010, 02:21 PM
pana651's Avatar
pana651 pana651 is offline
LRFFLR
Member Number: 3098
I agree with turkman and stburr91 : great stuff, love it. Look forward to next post
Old 10-04-2010, 02:27 PM
The Stray Cat's Avatar
Everybody Needs Rock N Roll
Member Number: 4514
B/S/T Feedback: (45)
X3 on the roofrack and the lighting! This truck is destined for the top builds!
