Old 01-11-2007, 10:35 AM
635's Avatar
635 635 is offline
Staring at unfinished projects .....
Member Number: 308
Originally Posted by ST1100 View Post
Methinks you will defenitely need that outher tube/sleeve to ensure alignment, otherwise that axle stubs are gonna wobble around...
Robbe axles... hmm...
The tube Iīll press over the joint between the end of the driveshaft and the extension will have 6 mm inner and 8 mm outer diameter. That should avoid any wobble.
Another thing is the bending moment, the extended shafts put on the narrow axle case but the Robbe Panther and even the Bauteil1 trial trucks use the same case so this should work.
  #92
Old 01-15-2007, 06:28 AM
635's Avatar
635 635 is offline
Member Number: 308
The rear axle is done, I glued all parts of the extensions with 2-components epoxy glue. The hexes don`t use the usual pin but two flat spots and fit perfectly here.
Old 01-15-2007, 08:30 AM
It sure looks strong enough. Will the right side come un-threaded as you drive?
Old 01-15-2007, 08:40 AM
635's Avatar
635 635 is offline
Member Number: 308
I donīt think so, Stu. All parts including the threads are glued together with that really strong epoxy glue and baked in the oven at 180°C.
The rear pillar is lengthened and I got my third victim ...
Old 01-15-2007, 09:00 AM
ST1100's Avatar
ST1100 ST1100 is offline
Member Number: 1254
Assuming thus is the thrusty old UHU-Plus I would agree and state that only C4 or nukes could seperate those again...
That axle looks pretty good and the round pumpkin gives it a scale appearance with those semi wheels
I'm only not sure about the outer single shaft-bearings. OTOH is this not a trial-rig and will see flat roads primarely
regards
M.Brunner
"HUMMER, like nothing else"
Old 01-15-2007, 09:24 AM
635's Avatar
635 635 is offline
Member Number: 308
Martin, yes, I used UHU Endfest300. The driveshafts are running on one bearing at each end and are 6 mm diameter. For on-road use, that should work.
Old 01-15-2007, 01:03 PM
Another one? How many must die to satisfy your madness?
Old 01-15-2007, 01:58 PM
Slyp Dawg's Avatar
Slyp Dawg Slyp Dawg is offline
git 'er done!
Member Number: 298
What was it they used to say? Carrying 1 person, it's a 'Yugo': 2 people. 'Wego': 3 people, 'Wontgo' Chris
Old 01-15-2007, 02:30 PM
635's Avatar
635 635 is offline
Member Number: 308
Stu, they donīt die, I give them a new life (hopefully ) !
Old 01-16-2007, 07:59 AM
635's Avatar
635 635 is offline
Member Number: 308
As the semi leaf springs are much too hard and too "curved" I made my own leafs. The alu pieces are necessary to get the leafs outside the frame.
Old 01-16-2007, 10:31 AM
635's Avatar
635 635 is offline
Member Number: 308
The second leaf is done, too. I used a semi damper for a mock-up; it looks scale but actually it isnīt a real damper as thereīs only a small spring inside.
Old 01-16-2007, 10:50 AM
Jugg2Driver's Avatar
Member Number: 3
Very nice!
ST1100's Avatar
Member Number: 1254
What have you used?
Or is your wiffer now screaming and nagging over a dysfunctional cable reel in the vaccum-cleaner
regards
M.Brunner
Old 01-16-2007, 11:11 AM
635's Avatar
635 635 is offline
Member Number: 308
Matt, thanks !
Martin, where did you get that pic of my wife .... ?
Nah, the vacuum-cleaner is still working! Itīs steel strap thatīs used for keeping together building materials like bricks or to strap them to a pallet.
We rebuilt our terraces last year so I have a nice stock of it. It works fine when you donīt overbend it. Itīs much softer than the Tamiya semi spring material so you can adjust the spring rate by adding a few leaves.
Old 01-17-2007, 08:47 AM
ST1100's Avatar
Member Number: 1254
Actually borrowed from another forum; we were chatting about high-end speakers (read: manly man, refrigerator-size speakers ) as one brittish lad sudenly posted: "...while at home I usually listen to this...<nagging wife>"; laughed my arse off at this piece of britt-humor never got an answer on my inquiry about her crossover frequency though...
I reckon, but isn't that too soft? I got semi-leafs here and figured to undrill the rivet and use only one or two plates.
regards
M.Brunner
Copyright Đ2004 - 2019, Scale 4x4 R/C
