Old 03-03-2009, 03:41 PM
Boone's Avatar
Boone Boone is offline
Starting Over Again!
Member Number: 3771
OK guys, been itching to do more with this Sammy, but with out the chassis parts, I found a little I could do! I shot the body with gun metal grey, applied the decals, and out-lined the body lines! I will probably start painting the interior tonight! I have to make a spare tire mount and roll cage too! After painting the shell, I kinda like the yellow wheels with the gunmetal grey! what do you guys think?
I am tossing the ideal around of making some body armor, I have the diamond plate styrene already, but I was wondering if any of you know if some one makes scale diamond plate aluminum???
I would be a excellent way to bolt the shell to the interior as well! If you could hook me up, that would be great!! Your input is always welcomed!!
Old 03-03-2009, 03:49 PM
AeroSynch's Avatar
AeroSynch AeroSynch is offline
Oh Snap!
Member Number: 2437
Looks awesome. Those are the 959 rims correct?
Luis, AeroSynch Team Driver.
Old 03-03-2009, 03:58 PM
Vanner1993's Avatar
Vanner1993 Vanner1993 is offline
Vanner, Member of RWRC
Member Number: 4615
Nice, I like the paint choice
{IF THE VAN IS A'ROCKIN DON'T COME A'KNOCKIN}2%
Old 03-03-2009, 04:03 PM
Boone's Avatar
Member Number: 3771
Yep, Luis they are Tamiya Porsche 959 wheels, they are around 1.6 or 1.7's and a little narrower that the standard 1.9's. The trick with them is that they use a smaller hex, so you would have to modify your wheel hexes to make them work! I used the 959 wheel hexes bolted on top of the losi plastic hexes, and the took the cut off wheel on my dremmel and cut the plastic hex to match the 959 hex! I'll have to wait until its a runner to see how well it works!
Boone's Avatar
Member Number: 3771
Thanks Vanner!
Old 03-03-2009, 04:05 PM
Boone's Avatar
Member Number: 3771
Which do you guys think would look better for the interior color, black or grey??????
Old 03-03-2009, 07:00 PM
1BadJeepBruiser's Avatar
1BadJeepBruiser 1BadJeepBruiser is offline
I build lots of Toyotas
Member Number: 188
B/S/T Feedback: (9)
Gray, this way you can see all the awesome detail
Wedico makes some scale diamond plate in aluminum, here is a link : http://www.gardentrucking.com/produc...ginals/471.jpg
I have used it before myself, kinda pricey but is nice.
-Mike
MSD Team Driver RC4WD Team Driver
TCSCrawlers.com
Old 03-03-2009, 07:36 PM
stub's Avatar
stub stub is offline
Member Number: 2588
Lookin nice... Cant wait to see more.
Old 03-03-2009, 10:18 PM
Boone's Avatar
Member Number: 3771
The interior is painted, I need to figure something out for the gauges! More to come!!
Old 03-03-2009, 10:21 PM
Boone's Avatar
Member Number: 3771
-Mike
Thanks for the heads up Mike!
Thanks, I just posted some more for ya!
Old 03-03-2009, 10:30 PM
4RUNN1's Avatar
4RUNN1 4RUNN1 is offline
Member Number: 3400
I'm speechless
Old 03-03-2009, 10:38 PM
pantablo's Avatar
pantablo pantablo is online now
Mr. Tire Guy
Member Number: 3012
color looks great! definitely grey on the interior to show off the detail-which is great too! awesome build. I'm digging the yellow wheels too.
1.6-1.7 you say? mmmm must know more...
Pablo
Old 03-03-2009, 10:47 PM
holdenhz's Avatar
holdenhz holdenhz is offline
Member Number: 3987
Looking mighty sweet boone
Color choice works as well,not sure on the rims.
For the gauges print out some dials,cut them out.
Then put a light covering of clear nail polish on the surface they will be mounted on then put the paper dial on it and let it cure.
If the dial surface has a lip around it you can then load up the face of the dial with a couple of drops of nail polish it will look like it has glass over it when it dry's.
Plus it is all water proof.
NO MATTER HOW HARD YOU POLISH IT A TURD IS STILL A TURD.
but you can allways roll it in glitter!!!
Old 03-03-2009, 10:59 PM
Boone's Avatar
Member Number: 3771
Thanks Pablo, the wheels measure 1 13/16 inch at its widest point top to bottom and is 15/16 inch wide!! They are getting hard to find though!
I have the white version of these wheels coming,(even harder to find!) Thanks for the kind words!!
Originally Posted by 4RUNN1 View Post
I'm speechless
Thanks 4RUNNER1! Don't you know I'm trying to impress!
Old 03-04-2009, 01:51 PM
pana651's Avatar
pana651 pana651 is offline
LRFFLR
Member Number: 3098
Awesome job on the little Suz
Interior looks superb, and so do the wheels with tires, just perfect!
Personally wouldn't I go for the yellow wheels, although it's not too bad either...
