Old 05-16-2012, 09:26 AM
williamg williamg is offline
RCMT'er
Member Number: 806
that looks unbelievably mean that last shot.
_ _ _ Email Me here
Old 05-16-2012, 04:28 PM
wireman969's Avatar
wireman969 wireman969 is offline
Member Number: 9266
Beastly lookin rig !!!!!!!!
Old 05-19-2012, 11:18 AM
scalersince08's Avatar
scalersince08 scalersince08 is offline
mid level fab man
Member Number: 9697
this thing is bad man the cleanness of it but the cnc/mill work is spot on love it good job
Old 05-28-2012, 07:06 PM
STANG KILLA SS's Avatar
STANG KILLA SS STANG KILLA SS is offline
The Scale Shop
Member Number: 1526
well i went ahead and did the XR mod to fix my tire scrub.
parts!
since there were no pics or instructions on the beef tube thread, i didnt have a clue what was needed to do this mod. so i just guessed and figured things out as i went. no clue if its right but i made it work i guess.
first i dremeled the inside and outside of the outer part of the axle case smooth removing the raised parts. also i need a way to secure the Beef Tubes to the housing , origonally i was going to use the origonal case Cs set screw holes, but after dremeling there was only 1mm of material left. So the area between the shock mounts looked the thickest and inconspicuous so i drilled a hole there.
next i drilled and taped matching holes in the Beef Tubes
then i screwed the Tubes to the housings, and then drilled and taped holes for the Cs
then reassembled everything
and put everything back on the truck. just need to make new steering and tie rods. ill also probly move the panhard rod mount out to the C. making the rod longer further eliminating axle swing.
Old 05-28-2012, 11:55 PM
Bulldog's Avatar
Bulldog Bulldog is offline
GIT-R-DONE!!!
Member Number: 10058
Thanks for the xr mod mini tutorial. I was curious about it myself. Looks good!
Click here for some hill killin' southern buggy Action.
http://www.youtube.com/watch?feature...&v=XMbZnCCHUdA
Old 06-20-2012, 10:26 AM
The Scale Shop
Member Number: 1526
well in order to use the Mayhem wheels, because the hex pocket is so deep i had to use standard Axial thick hexes with the nipple. well i wanted to use the scx-10 thin hexes to narrow the track, but mostly to reduce more tire scrub with the thicker XR knuckles. but as you can see that wasnt possible.
so i got out the hack saw
problem solved
then i got all the steering links made, and decided to move the panhard axle mount from the AX10 location out on to the XR "C". this allowed the panhard rod to be 1" longer further eliminating axle swing.
finished the truck just in time to try it out at my annual Rock The Lake 3 scale comp.
truck did very well dispite needing a BEC. the servo winch and steering servo just didnt have enough umf to move this heavy truck.
ended up actually winning class 3."thumbsup"
[IMG]http://i486.photobucket.com/albums/rr227/sgtsteven/Rock%20the%20Lake%203/big*****12.jpg[/IMG]
[IMG]http://i486.photobucket.com/albums/rr227/sgtsteven/Rock%20the%20Lake%203/big*****7.jpg[/IMG]
[IMG]http://i486.photobucket.com/albums/rr227/sgtsteven/Rock%20the%20Lake%203/big*****9.jpg[/IMG]
The Scale Shop
Member Number: 1526
video from the event (none of BB though )
Old 06-20-2012, 11:15 AM
Cruisi's Avatar
Cruisi Cruisi is offline
It might be slow , but a Toyota can go anywhere !
Member Number: 16604
Nice pics man
"If parts aren't flying, your not trying."
Old 06-20-2012, 11:17 AM
Cruisi's Avatar
What seats did you use ?
Old 06-20-2012, 12:46 PM
The Scale Shop
Member Number: 1526
they are custom made kirkly race seats from Norm @ Team 3 six
