Go Back   Scale 4x4 R/C Forums > Scale On-road R/C > Car Discussion > Car Gallery
Car Gallery Show it off!
Old 06-29-2006, 03:57 PM
Bugged Bugged is offline
Member Number: 848
I now know what im doing tomorrow afternoon....Just found 2 metres of black pvc tubing in the shed....Which i bought for some reason ( Cant remember why )
So its off to the mitre block, Cut some rings, Charge some cells, Slap the rings on the rims....And et voila....Im off drifting ! ! ! !
Old 07-07-2006, 01:04 PM
BrockGrimes's Avatar
BrockGrimes BrockGrimes is offline
Modifier
Member Number: 606
I run a TC4 with a 8 turn double flat wire motor.
With HPI Stage D 26 mm tires.
Although with an 8 turn you can drift with stock tires.
HPI makes 3 drift tires the Stage D in 26 and 30mm which are slicks, and a drift tire with tread, all 3 are made with hard compound rubber.
I'm doing a build http://www.beatyourtruck.com in the forum under general on-road if your interested.
http://img2.putfile.com/main/9/26320504123.jpg
When approaching a four-way stop, the vehicle
with the largest tires always has the right of way.
Old 12-10-2006, 03:23 PM
peeprox's Avatar
peeprox peeprox is offline
Master of the garden shed kingdom
Member Number: 696
im running my tl01 in the tyres it came with from ebay which are very hard. with my 19t round brush motor, on a slightly damp road (rather common in sunny old england ) i can drift perfectly, well its more like a powerslide, but its much more controllable than it was on PVC, it will accerate to top speed (fast) with next to no wheelspin, but i can hang the back end out around corners. oh, and the front diff is locked as well to stop it spinning out. when i was racing it, i cud pull ahead of the other cars on the track (non drifters) and powerslide around the end of straight corner .
Old 03-28-2008, 08:16 PM
Biscuit Biscuit is offline
Member Number: 3289
Why is this here in the bike forum?
Old 03-29-2008, 02:58 AM
635's Avatar
635 635 is offline
Staring at unfinished projects .....
Member Number: 308
Fixed it
Old 03-29-2008, 03:01 AM
gearhead's Avatar
gearhead gearhead is offline
are you economically viable????
Member Number: 2335
BROKE MOFO MEMBER #1
