Old 11-07-2010, 09:41 AM
stevehuckss396's Avatar
stevehuckss396 stevehuckss396 is offline
Member Number: 7455
Originally Posted by caprinut View Post
I'm loss of words....
Here's a few!
"Do you like your beer in the can, or a frosted mug"
"I'll just sign this check over to you"
"Sure you can borrow my ferrari any time you want"
  #167
Member Number: 7455
Hello All!
I made a few valve spring retainers this morning.
I turned the OD on a piece of 1/4 inch brass about an inch long and faced the end.
Then spot drilled and drilled the ID about an inch deep.
Then I used an endmill to make the flat bottom pocket for the spring clip.
Then I cut a groove deep enough to create the step in the bottom that will insert into the spring.
Then just move over the length of the step and part off the piece. Then starting with the step of making the pocket with the endmill, I continued until the inch of turned material was gone. It took 4 cycles of 1 inch of rod to make 43 pieces with 2 boo boo's.
That's it for the day. I have a half dozen or so club members coming over to hang out, eat, and brain storm about getting there stuff going. Should be a great day!!
Old 11-07-2010, 09:48 AM
Metal Militia's Avatar
Metal Militia Metal Militia is offline
VARCOR
Member Number: 5922
amazing, keep it comeing
Old 11-14-2010, 02:59 PM
Member Number: 7455
Hello All!
Good day in the garage today. After pressing in my valve cages, I spent the day redrilling all the intake and exhaust passages. After that was done I came in the house and made some g-code and started on some rocker arms. I managed to cut the side profile and then after they were broken apart, I milled the slot in the top. I think I am going to make a fixture of some kind so I can finish about 6 at a time.
Old 11-14-2010, 03:06 PM
rangerboy's Avatar
rangerboy rangerboy is offline
Mud slt!
Member Number: 1264
that saved some time
Old 11-14-2010, 03:42 PM
Member Number: 7455
You have no idea!! That sheet is one of two sheets. I am making 40 rockers, 20 left and 20 right handed.
Old 11-19-2010, 07:39 PM
Member Number: 7455
Hello All!
Started finishing the rockers today. Made a fixture out of some scrap aluminum. Wanted to do 8 at a time but the aluminum had other plans. I was able to make 6 at a time. The parts were drilled for a 2-56 screw and then the outer shape was cut. I'm not real happy with some of them so I may make a second batch. I do like the the way the fixture worked out. I may make a better fixture. No matter what I decide, I won't be doing much any time soon. Work is getting busy!
Old 11-19-2010, 08:25 PM
kidcrawler's Avatar
kidcrawler kidcrawler is offline
Member Number: 13002
thats sick,are you going to make a scaler for it to go in?
Old 11-20-2010, 05:59 AM
Are those slots long enough for the rockers to work? Looks like they'll bind up before the valves open
Old 11-20-2010, 05:00 PM
maintguy69's Avatar
maintguy69 maintguy69 is offline
I'm not ignoring you. Your comment is awaiting moderation
Member Number: 8868
all depends on the lift of the valves...... being that thhe rocker studs are so close to the valve, I'm guessing isn't gonna be much
Sometimes I pretend to be normal, but it gets boring, so I go back to being myself.
Old 11-20-2010, 06:02 PM
blwn71's Avatar
blwn71 blwn71 is offline
always working on something
Member Number: 1708
simply amazing very wanderful work love this build keep the pics coming thanx
Old 11-20-2010, 06:29 PM
Member Number: 7455
They will work fine. The lift is only .070 inches.
Old 11-24-2010, 06:40 PM
Member Number: 7455
Hello All!
Well, I have designed a new fixture for the rockers. I have written the new Gcode for the fixture and the rockers. The way I would like to proceed is to use the CNC machine to cut the fixture out. This way the X and Y axis will already have reference and save alot of setup and everything will have a high probability of coming out real nice. The problem with all that is the amount of time it will take to do all that. I was hoping to do it on a weekend so I will have all day and wont be out in the garage late.
Not having a day off last weekend and this past weekend, I have gotten tired of doing nothing, waiting for rocker arm day so i decided to make some lifters. I didn't take many pictures because they are a very simple part. I managed to make a full set of 16 today so i am half done. After this photo was taken, I turned the part around and faced off the little nub and polished the bottom real good. It will be rubbing on the cam so we don't want any sharp edges.
Old 11-24-2010, 07:31 PM
trucker47's Avatar
trucker47 trucker47 is offline
To many ideas and not enough time or money
Member Number: 3721
wow this engine is simply amazing! how much would you say is manual machining and how much is CNC?
Chris
Old 11-24-2010, 07:44 PM
Member Number: 7455
Chris
man/cnc is about 30/70 right now but once finished it will be about 50/50.
