Old 01-28-2011, 02:53 PM
v8chris's Avatar
v8chris v8chris is offline
Honk Honk
Member Number: 14177
Nice
What power output are you hoping for?
Anymore Updates?
  #257
Old 01-28-2011, 04:37 PM
stevehuckss396's Avatar
stevehuckss396 stevehuckss396 is offline
Member Number: 7455
Originally Posted by v8chris View Post
Nice
Anymore Updates?
I don't have any way of measuring output.
Nothing further after the carb. Hope to make a piece or 2 this weekend.
Old 01-30-2011, 05:08 PM
Member Number: 7455
Made a few carb parts today
Air bleed adjust screw
Fuel adjusment screw
Fuel fitting
Finished the machine work on the rear float bowls by adding the fuel passages.
Old 01-30-2011, 05:21 PM
trucker47's Avatar
trucker47 trucker47 is offline
To many ideas and not enough time or money
Member Number: 3721
awsome! by the way how tight are your tolerances?
Chris
Old 01-30-2011, 05:53 PM
Member Number: 7455
Chris
Which one's?
Most are loose but crankshaft and pistons need to be inside a thousand of an inch. All depends.
Old 01-30-2011, 06:26 PM
trucker47's Avatar
Member Number: 3721
the ones for i geuss non-internal component like the carb you are working on, for example how close the size of the carb needle needs to be to real size
Old 01-30-2011, 06:57 PM
Member Number: 7455
This carb is just like a drum style RC carb. It is just made to look like a automotive carb. There is no way joe schmo could make a 1/5 scale holley carb with normal home shop tools. The problem with using RC carbs is, the fuel is alcohol or nitro and RC carb flows alot more fuel to air for those fuels. Gas requires less fuel to air so I need to make my own carb. May as well make one that looks cool.
The things that require tight tolerances are valve stems, pistons, crankshafts, anything press fit like cylinder liners and lifter bushings.
Old 01-31-2011, 12:43 AM
trucker47's Avatar
Member Number: 3721
cool, another question hahaha im intrested in getting my machinst ticket when i get out of school and have finished my robitics degree (thats if all goes to plan) anyways onto the question, when doin manual machining how do you stay within tolerances? is it a type of thing where you cut a little and measure?
Chris
Old 01-31-2011, 05:44 PM
Member Number: 7455
Chris
I personally rely on the digital readout. If I need a 3/8 slot 1 inch from an edge. I would put in a 1/4 inch cutter and cut 7/8 from the edge to center of the bit and then move to 3/4 and cut my way back. It's like manual CNC only you have to do all the offsets in your head before you start.
Old 02-01-2011, 05:47 PM
trucker47's Avatar
Member Number: 3721
ahh i see, thanks
Chris
Old 02-04-2011, 03:46 AM
jan_m's Avatar
jan_m jan_m is offline
too many projects, to many ideas
Member Number: 6746
Amazing, this is a piece of art and I mean every piece of it
trying to write English
Old 02-06-2011, 02:34 PM
Member Number: 7455
Scratch carburetor off the list. Thanks to Mr. Bob Farr I was able to get a piece of brass to make the barrels. Everything is made except the throttle lever and the gaskets. I think I'm just going to wait until everything is done and make gaskets for everything all at one time.
The screw to the right adjusts the fuel and is adjusted at full throttle. The screw in the center will adjust the air bleed to lean out at idle.
Old 02-11-2011, 08:44 PM
Member Number: 7455
Well I'm getting real close. All i need to do is part off the ends, cut a flat on the front shaft and thread the rear shaft. I'm not going to do anything fancy like counter weights. I don't want to screw it up.
Old 02-11-2011, 08:47 PM
kidcrawler's Avatar
kidcrawler kidcrawler is offline
Member Number: 13002
Did you make that crankshaft on the lathe?
Old 02-11-2011, 09:03 PM
Member Number: 7455
Yes I did. The squares on the end has the 5 centers drilled into them.
