Old 04-02-2019, 09:15 AM
4x4lover4499's Avatar
4x4lover4499 4x4lover4499 is offline
To many projects not enough time.
Member Number: 16060
A short clip of Vertigo climbing a short hill.
When in doubt, Throttle out!
Old 04-02-2019, 09:27 AM
cambodian tire's Avatar
cambodian tire cambodian tire is offline
Member Number: 378
Looks great! love the Bronco body, probably the only one on scale 4x4 rc runnin' some low gears in there by the looks of it? I did the same as I was only running a brushed 55 turn and it seemed to run outa snot with 2.2's if not geared pretty low:thumbs:
Old 04-02-2019, 03:16 PM
I am running a brushless 3000kv 4 pole motor restricted to 60%. Gearing is 14/87 with Underdrive rear (43/13), and Overdrive front (36/14) ring and pinion gears. She has plenty of power at all throttle positions and eats battery Mah for breakfast, lunch and dinner lol. She also destroys front cvd pins. Thus the reason for the new axles. The Universals provide tons more steering, and have lower gear ratios (8/30) in the housings. plus the housings provide a lot more clearance.Parts availability is also a concern as the ax10 axles have been discontinued now. So no reason not to upgrade.
Old 04-02-2019, 11:25 PM
Member Number: 378
Sounds like a beauty set up Way too advanced for my scalers... My monster truck maybe... if it ever survives running a battery that is... Keep us updated. I'll live vicariously through you actually running your stuff!... Mark
Old 04-03-2019, 10:53 PM
Old 04-05-2019, 12:00 PM
Got the body fully mounted on new chassis
Old 04-05-2019, 12:38 PM
Member Number: 378
Looks perfect on there looks just right with 2.2's -must mean thats a pretty big body The wheelbase worked out perfectly, or did you have to make new links?
Old 04-05-2019, 10:57 PM
I made new links... It sits at 12.5 inches, and measures 9 inches at the doors.
So yes, huge body, a true 1/8 scale.
I have the front axle pushed forward a bit and may have to do a bit of trimming up front to clear full steering lock.
Old 04-06-2019, 02:05 PM
Member Number: 378
That is huge!! I have a soft spot for the big scales. My very first "scaler" was a black foot bodied truck in the early 90's.Then a 1/6th build that brought me here after many years of just bashing with buggies. How do you have the front end held down? Love the rear tilt mount.. Genius
Old 04-07-2019, 12:18 AM
That rear mount took me 4 attempts before I was happy with it!
The front is held down with body clips in the stratiegic location of the hood pins molded into the body.
You can see the pins sticking through the hood right in front of the hood scoop.
Old 04-07-2019, 12:43 AM
Member Number: 378
Oh I gotcha, great spot for hood pins Very nice
Old 04-07-2019, 06:36 PM
Spent some time on her today...
Did some minor front trimming of the fenders.
Limited and remounted the scx10 shocks back up front with the much softer dual stage springs.
Finished the panhard bar, and the steering link.
Greased the ring and Pinion in the axles.
Fiddled a lot.
And to give you an Idea of the size.....
Sitting next to my lcg Slash....
Old 04-08-2019, 12:14 AM
Member Number: 378
Ooh I love the big scale! They are so much more realistic to watch bouncing around over obstacles. Nice to just "fiddle" sometimes tweaking stuff and getting it just "so". Beats the head scratching, grab every tool you own and still do everything twice as far as relaxing goes
Old 04-08-2019, 09:18 AM
Agreed on both points.
I got the electronics in last night, and now I just have to figure out where to put the mile long marine rx antenna. It reminds me of the old school FM rx antenna's.
Old 04-09-2019, 01:50 AM
Member Number: 378
Lol reminds me of everyday. Of my bazillion radios only two in the house are 2.4. One in my axial and one in my eldests's crawler. Long antennas are just normal around here lol.... take care for now... Mark
