Go Back   Scale 4x4 R/C Forums > R/C Manufacturers/Venders/Retailers > Rogue Element Components
Rogue Element Components Fine Custom and Limited-Edition Machine Work
View Poll Results: What 3rd color option would be wanted?
Blue 4 36.36%
Green 0 0%
Red 8 72.73%
Other 1 9.09%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
Old Yesterday, 11:04 AM
toyranosaur's Avatar
toyranosaur toyranosaur is offline
I WILL Hijack & De-Rail your thread into uselessness!
Member Number: 128
Boy, now THAT's an interesting thought right there. Ano usually used 'fade-resistant' dyes, but the Sun doesn't care about that, given time. I wonder if there is another High-UV source that does not cost much and can be tried? In theory it should work- Stu, you have an active mind for sure.
What ticks me of is, I drive these up to the Springs. I talked to the actual chap doing the work and the owner, make sure they know just what is wanted, that they carefully handle several months of work, hit the correct color, put enough juice to the plates with the screws, mount the centers so there is not a mark from same in a critical area........Like so many business these days, it seems their payment is the only important thing to them & the customer is an inconvenient necessity. You chaps might not know how anal I am about even minor details, so this hit me right in the face (Actually about 3 feet lower.)
Anyway, divorced from the circumstances, and the fact that they are not my original vision, the color is kinda growing on me. Suing that bass turd is not practical, nor is any other option, or I'd have been all over it: So acceptance is hard but ultimately the only real route available, and it is happening for me which I'd have never bet on- These wheels are very special nonetheless.
I have neglected to post pics of the orther centers that are done, I'll remedy that tonight/tomorrow. Looking at 30-45 days and do not foresee any technical issues ahead, just lots of....Time. Cheers to all you spectacularly decent folks, Chris REC
CLICK HERE to add your name to my Private Mailing List: Rogue Element Components
  #152
Old Today, 05:21 AM
Hang 'em up next to the welding table? You'd probably have to burn a lot of wire to have a noticeable effect, though.
Apparently, heat (over 400F) can fade anodizing, too. Bake a sample in the oven and see what happens.
Old Today, 06:09 AM
Here you go. Guess which one got hit with a MAPP torch for 30 seconds.
This is a thin piece, so it heated up quickly and the color change was very rapid. You'd have a little more control with a thicker piece like a wheel center, but maybe not enough. By the time I saw it begin to change and took the heat off, the change had started to run away.
Interestingly, the blue changed to red. I only heated the red bit but enough heat went thru to change the blue.
If anyone wants to try this, I'd suggest keeping a bucket of water handy, and drop the piece in there RIGHT NOW when you see the color change to what you want.
Want to fade all 4 of 'em to exactly the same shade? Stick 'em in the oven and keep watch.
Old Today, 06:30 AM
Experiment two: Propane torch. More time, better control. I had a few seconds to see the change and remove the torch and got a true fade to pink.
Second pic shows the uneven fade on the blue bottom piece. If anyone wants to try this, you will probably have this effect near the wheel hex, where the material is thicker.
Also notice the cracking/crazing effect on the anodized finish. This is the first thing you'll see when the color starts to change (and will probably annoy anyone who's paying big bucks for anodized wheels). Micro-cracks form in the ano and the edges start to glow. When you see that, it's gonna change pronto.
I should add that I completely failed to read the parts with a temp gun. Only just now thought about it
