Old 06-06-2019, 05:09 PM
scaleraddict scaleraddict is offline
Member Number: 20917
This one has been delayed for a while. Have the mounts in place and the tools but didn't found anything suitable for making the straps to hold everything
When doing the strap for the goggles, remembered to do this also and the rubber strips do the job well. Tooling foil strips for the buckles(that's the word?)
  #122
Old 06-07-2019, 05:43 PM
Looks like a fine set of buckles and straps to me
Old 06-14-2019, 04:24 PM
thanks!
Now a small detail that it's almost invisible but wanted to do it anyway
Each road wheel arm has a piece atached to the hull where the axle pivots
So printed 8 of these:
OD paint to cover it all
These were meant to be bolted on but will try with glue only, for now
Old 06-18-2019, 04:09 PM
My goal of closing off the drivetrain it's closer to finish.Needed something on top to keep away dirt and sand
First idea was a standard cover but started to mess with the 3d printer and decided to do a more elaborate clear cover to see the gears working(might sound like a joke but many non-rc people who see this truck don't understand how this truck moves or why it needs 2 motors...)
Old 06-18-2019, 04:25 PM
thats cool
Old 06-19-2019, 03:22 PM
That's a good looking drive train. That clear cover was a great idea.
Old 06-19-2019, 05:55 PM
thanks guys
small improvement :
Put some rubber over the hull sheetmetal to cover 2 previous holes from the first gearboxes and to supress some noise
And a small rubber lip on the cover to keep sand and dirt away
Old 06-24-2019, 12:46 PM
The M548 often came with the winch to load cargo,mainly ammo
I thought mine would look more complete with it so...3D printed the I-beam and the winch:
It's held in place with small zip-ties:
It has a chain, only needs a hook or a D-ring
Old 06-29-2019, 02:11 AM
I'm suprised they used the top bows for a gantry crane, but that looks pretty killer!
Old 06-29-2019, 04:53 AM
Thanks...now that you've mentioned, don't seem a great idea but it worked
To make it worse, it's only mounted on 2 of the bows
