Old 07-16-2008, 11:48 PM
finishline's Avatar
finishline finishline is offline
CEN*CAL*CRAWLER
Member Number: 3007
used one of my extra gears from the back diff on cc-01 axel to lock the front diff . all i did was placed the extra gear between 2 of the gears to lock it. takes alittle work to get them lined uped so plate sits flush on it but it works well and you can always remove it when ever you want
Old 12-13-2008, 06:19 AM
Old Skool's Avatar
Old Skool Old Skool is offline
Old Skool
Member Number: 4009
Originally Posted by captain scale View Post
Why doesn't someone like RC4WD make some copies of Tamiya's G Parts #9005422 to sell for locking Tamiya differentials?
I am in the process of doing this and will let you know how it comes out.
Old 02-21-2009, 12:55 PM
rcjunky3's Avatar
rcjunky3 rcjunky3 is offline
SCALE CORRDINATOR
Member Number: 3575
excellant trick
Old 02-21-2009, 05:12 PM
spencertrax's Avatar
spencertrax spencertrax is offline
Scale Craftman
Member Number: 2783
Works good, have done this simple mod in a few of my trucks.
AX10 RTR, TA02 Trailtruck, MLST, More Tamiyas !
Old 02-28-2009, 10:14 AM
xtx671 xtx671 is offline
Member Number: 7011
I know the crawler store has some lock diff's. but I also want to save some cash JB weld sounds good if it can be remove by boiling it. yah I do that to my tires too . thanks going to lock mine
Old 06-14-2009, 11:06 AM
The_Stuff's Avatar
The_Stuff The_Stuff is offline
Thinking Big
Member Number: 1490
Originally Posted by Jugg2Driver View Post
One thing I learned about locking the front diff of the Jero, is that if you take on of the sider gears off its shaft and intall it (just move it over into the empty space) so that the teeth of two spider gears touch, it will effectively lock the diff and be non permenant.
Jugg, that is the easiest and simplest way yet i have heard to lock a diff. its so easy its almost retarded! but hey, i did it and see how it goes!
RC's are like pringles!! YouTube - http://www.youtube.com/user/thestuffz
Facebook - www.facebook.com/Thestuffz Blip TV - http://thestuffz.blip.tv/
Old 08-01-2009, 03:36 AM
Def4x4's Avatar
Def4x4 Def4x4 is offline
Member Number: 4139
I have locked one diff with hot gleu in one of my CC01 truck. I did it with transparent hot gleu. But now i have a strange sound in my axel, i think it comes through the hot gleu! Meby it comes i did not enouf gleu in it when i mounted the 2 alu parts together and it looks like their is some air in it!
An other friend of me told me hey sad you have not the good gleu used, their are 2 tipes: the transparent type and the white type.
Hey sad to mey i must use the white type, that type is much better flowing in all and the litle holes of the diff!
Try to do it with the white type hot gleu, meby thats better and is that strange sound going away!! I hope so.
Old 08-01-2009, 03:43 AM
mongoose78's Avatar
mongoose78 mongoose78 is offline
Gimme a beer and a smoke. We're in for a long night.
Member Number: 8569
i had just used Red or Green lock-tite
Old 08-01-2009, 02:45 PM
Def4x4's Avatar
Member Number: 4139
And how dos that work!!
Old 08-01-2009, 03:26 PM
mongoose78's Avatar
Member Number: 8569
just like regular glue fill the diff gears with it, rotate it and when it drys....a locked diff
Old 01-19-2010, 03:43 PM
mikeg8 mikeg8 is offline
Member Number: 1587
Default Engineered solution?
Does anyone have an engineered solution to this problem, eg a movable doohickey to lock a half-shaft to the diff casing (or something like that!)? I know lockable cross-axle diffs are available for the Big Rigs and the CC/XC (I think), so I know it can be done...I just don't know how!
Old 01-19-2010, 10:07 PM
FreddyGearDrive FreddyGearDrive is offline
Member Number: 7681
The method I use,is drill through diff housing into spyder gear.Then thread spyder & drill hole in cover a little larger than bolt so it can move around in cover.
Put lock tight on screw & don't tighten bolt tight.Let sit 24hrs before useing.
Works perfect!
FGD
Old 01-20-2010, 02:16 AM
Tzi Tzi is offline
Member Number: 897
Thats a very cool idea... I prefer to fill the casing with blu-tac tho
I used to tell people the easiest way was to move one of the spider gears from its stock location, and position it between the other two.
It locks solid, is nice and quick to do as you build, and it is completely reversible.
But after fitting rc4wd outcropper tyres, and a brushless outrunner motor, I found that the diff was a bit loose.
Upon further inspection I found that the stress from the extra grip had caused the spider gears to walk a little and force the outer casing open, partially stripping the thread in the process.
I put it all back together, locktited the outer casing screws, and all was well.
6 months later, the diff partially started working accompanied nice crunchy sound.
I pulled it apart to find that the 'loose' gear (which should be neatly seated between the other 2) had walked itself up an over another gear, back into its original location, snapped a shaft off from the tri-thing in the middle, and forcing the outer case open in the process.
I have now replaced the spider gears and center-bit, and filled the casing with so much blu-tac it cant move.
Its a much better solution, and allows the gears to move a little if they wish.
LSD effect can be achieved by using varied amounts of blu-tac, but dont mix it with grease as it becomes sticky/tacky grease, and gets everywhere
Old 12-28-2013, 10:24 AM
boss4457 boss4457 is offline
Member Number: 21373
Default what
about the pins need pic cause im confused
Old 02-10-2014, 11:51 AM
johnnyb johnnyb is offline
Member Number: 10123
Tamiya Hilux 1:10
Diffs locks with servos.
Exploded and details.
