Go Back   Scale 4x4 R/C Forums > Gallery > Scale 4x4 Galleries
Old 04-08-2017, 04:55 AM
bender81 bender81 is offline
Member Number: 25398
Default New to SCALE4x4R/C
Hi everybody im new on this site and i would like to knew what country you all are from and what you drive.Me i am from denmark and i have and custom scx10
Specs:
rc4wd 35t brushed motor
quicrun 1060 waterproof esc
Sanwa - AiRTRonic Mx-V 2,4 GHz Radio Set waterproof
orca inanite lipo 6200mah 7.2v 90c hardcase battery
Savox SC-1267SG Super Speed Steel Gear Digital Servo 21kg waterproof
1.9 steel wheels
1.9 114mm Off Crawler tires
Boom Racing Axial SCX10 2.2 Wheel widner (4) (Offset: +14mm) green
Steering Servo Half Arm 25T BIG Torque Aluminum green
Aluminum Adjustable Tow Hitch green
Xtra Speed VR Steel Front Bumper Winch Mount red
Aluminum 47MM Body Post black
Aluminum shock tower black
Universal HD stål drive Shaft
GPM stål spur gear 48P 81T black
axial scx10 alu axles green
GPM alu front C-Hub green
GPM alu steering links green
GPM alu rear knuckle arm green
GPM alu front knuckle arm green
Jazrider alu skid plate & linkage set green
alu center gear box mount green
3d printet roof rack
Scale accessory
Old 04-08-2017, 07:36 AM
Greetings and welcome.
Looks like you have a very nice SCX10.
Some really good parts on the list.
Luck on your tiny truck adventures.
Pretty sweet ride.
Old 08-28-2017, 10:27 PM
4RZee 4RZee is offline
Member Number: 25856
Nice truck
