Old 05-27-2009, 06:31 AM
spankrjs's Avatar
spankrjs spankrjs is offline
This Space for Rent
Member Number: 2108
B/S/T Feedback: (15)
Appreciate it chevy55
Nothing like the smell of a new Tamiya in the morning......
  #77
Old 05-27-2009, 07:25 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Step 18
Assembling Cam-Locks, Installing Receiver On/Off Switch
You are supposed to twist the springs around the cam-locks. The pins in the bottom of mine were a little loose, so I pulled the pins, slid the springs on, then reinstalled the pins. I need to put a little CA on the pins so they dont fall out. There not terribly loose, but loose enough. Receiver switch screws onto the radio box lid.
Old 05-27-2009, 07:31 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Step 19
First plug in servo wires and receiver battery wire into receiver. Then install battery, then cover. You push the cam-locks down, then twist them, and they lock into place. Make sure everything is installed in the box properly before you push down cam-locks. If you force the lid on, you will probably break the plastic around the cam-locks. Last pic, kind of blurry, shows one of the cam locks locked down. Pretty tight fit inside the box. That old battery came with this Scorcher, and it still works perfectly!
Old 05-27-2009, 07:37 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Step 20
Installing the front piece of the receiver box. Receiver just fits inside this box. Run wires carefully so you dont smash or pinch them. Once receiver is inside box, line up front box with big radio box and screw it on with the 4 screws. Little front box has knotches, big box has tabs, so it only fits one way. Install the screws very carefully so you dont strip out the plastic. You dont have to torque these down super tight. Also, make sure you route receiver wire throught the proper hole in the front of the box. I think I was supposed to do that in Step 19, but forgot to. You can see that once all this stuff is in the radio box, there is no spare room
Old 05-27-2009, 07:46 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Step 21
Bolting radio box to chassis and hooking up motor wires. Set radio box on chassis, line up holes in bottom of chassis with well nuts in radio box, tighten down the 2 screws. Tighten screws down just enough to flatten well nut, which will then hold radio crate securely to chassis. Dont overtighten or you will bust radio box. Third pic shows how I routed wires out the back. Last 2 pics are too blurry to see, but they are supposed to show how the rubber well nut flattens out and pinches the radio box to chassis.
Old 05-27-2009, 07:52 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Step 21 continued.
Little square thing came with this Scorcher from previous owner. This is how the wires were connected. Pretty neat little thing. No way as efficient as more modern "No Loss" connectors, but its pretty neat old school technology (maybe its not that old, maybe they still make them, I've never seen one before) Anyway, insert the bare wire ends into each side, tighten down the screws, and voila, motor is hooked up. You also hook up the two smaller red wires, which have female spade connectors on them, onto the resistor at this time.
Old 05-27-2009, 08:02 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
After this step I decided to test the Scorcher out. Placed it up off the ground on a small box, turned transmitter then receiver on, and problems. Nothing major. The hump back battery had gone flat from sitting on the shelf too long without being charged. It had enough juice to make the servos turn, but not enough to make the motor spin. I also realized I had hooked up the servo wires to the wrong ports on the reciver. When I throttled, front wheels steered, when I steered, MSC moved. Switched receiver wires around, put in a different battery, and voila, worked like a charm. Following pics show a hump back batttery pack I had made. I ordered this battery when I bought a Super Champ because if you build a Super Champ stock, you pretty much have to use this style battery. Pics mainly show the technology advances, 1200mah vs 4500mah. My Super Champ will run for almost an hour off this one battery, and it is using a Mechanic Speed Control. Pretty good battery. Fits inside radio box perfectly as well.
Old 05-27-2009, 10:22 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Step 22
Assembling Tires and Wheels
After test running it, I couldn't wait to get the tires on it and try it out. Pretty simple step.
Old 05-27-2009, 12:46 PM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Step 23
Bolt tires on. Chassis is now 100% complete. Sorry for the kinda blurry pics, I'll take some better ones and post them up. Just gotta finish the body up now. Thats it for now
Old 05-29-2009, 09:11 PM
westbeach's Avatar
westbeach westbeach is offline
Member Number: 2823
Pretty Sweet Buy for sure! Are you going to keep up with the box art as far as paint goes?
Old 06-19-2009, 07:35 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
No Pics yet, Sorry Finished painting the driver, steering wheel, windshield wipers, taillights, and painted all the window surrounds black. I Should now be ready to finish assembling this build, hopefully this weekend. As always, I'll take lots of pics and post them up. Later
Old 06-22-2009, 07:30 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Been busy working on the 1:1 cj-7, but finally got some Sand Scorcher work done. First two pics show the front body post, Forgot to put it on during Step 23. It slides over the servo saver post and a grub screw holds it down.
Old 06-22-2009, 07:34 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Step 24
Attaching rear exhaust. I painted my exhaust a flat aluminum color, thought it looked better then painting it black like the box shows. Kind of helps it stand out from the black rear cage. Fairly simple, just place the little metal straps around the cage bars, tighten the little screws, make sure its straight, finish tightening, done
Old 06-22-2009, 07:41 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
I had finished detail painting the body last week. I painted all the window surrounds black, and I also painted the rear louver slots black, which is a big pain in the #$%@&*. I also painted the inside base of the rear lights silver, to kind of help the clear orange, red, and clear colors show up better. That is why the back has two silver spots, those two spots are where the rear light covers go.
I thought about painting the front half of each front window silver, to make it look more like an operable side vent window, but decided not to, for now. Maybe later.
Old 06-22-2009, 07:44 AM
spankrjs's Avatar
This Space for Rent
Member Number: 2108
Step 25
This is the real beginning of the "body assembly" steps. Get the glue ready. First pics show all the parts (minus a few screws). I'll kind of break this step into 4 parts. Pics of all the parts
