Old 11-01-2009, 12:35 PM
ThomasR's Avatar
ThomasR ThomasR is offline
Member Number: 3583
Default 4 Seater Sand Rail - UPDATE again.
This is my try on a 4 Seater Sand Rail. It is a Desert Storm Chassis from RC4WD which will be modified to meet my needs as I will not use the suggested Traxxas parts but other custom parts.
This is just early stage and there is not much done yet practically as I am still in the planning and finding out which existing parts may fit best before I start producing my on stuff.
Pictures show what parts definately will be used so far. I am trying to build it as close to the real thing as possible.
So the official 4 Seater Sand Rail Project is started
Comments are welcome...
Old 11-01-2009, 02:46 PM
volksrod68 volksrod68 is offline
Member Number: 474
Awesome start, nice trailing arms, they from the Scorpion-chassis'd cars?
Old 11-01-2009, 10:39 PM
ThomasR's Avatar
Member Number: 3583
Correct, they are the Kyosho trailing arms.
Old 11-02-2009, 06:23 AM
blackbeast44 blackbeast44 is offline
Member Number: 9129
i just love that chassis...planning on going with that for my build up as well...what are you running as far as your trans setup? also where did you pick up the killer scale looking ford powerplant in the back? lmk and cant wait to see more pics and or the end result
-joe-
Old 11-02-2009, 07:22 AM
ThomasR's Avatar
Member Number: 3583
Well, as I wanted to go with a scale V8 in the back there is not much available for the trans. First I planned to use a XR311 trans. It is small and looks great, but is weak I guess. So I am trying an Astute trans. It is compact, has a ball diff and variouse gear ration options and I can go back further with the output shafts. This is most problem cause the half shaft may hit the trailing arm in case they come out to far towards the front.
The powerplant is a Ford 427 1:12 scale (actually I think it is 1:10) die cast model. I got it from a German seller, but they are from US actually. Also a nice 426 Hemi engine in red available in the same size. They fit perfect to the 1/10. Unfortunately there are not more engines in this scale on the market. Mostly 1/6 or 1/4 but they are way too large.
Next stept is to make the front suspension working. Then I'll do the rear end.
Old 11-02-2009, 08:04 AM
ThomasR's Avatar
Member Number: 3583
as for the trans...I am pretty sure that also the HPI E-Firestorm trans will do a good job.
Old 11-02-2009, 02:16 PM
Member Number: 9129
yeh ive talked to a few people that said they also used a rustler/jato tranny...not sure how they fair to the firestorm one but...lol...yeh ill have to look into all 3 as an option....im going to try and find those motors online...it would be a killer touch to an allready hott *** chassis....but yeh keep updates on your project it looks great so far...and as soon as i start mine ill have to send you some pics to....look forward to more
-joe-
Old 11-09-2009, 10:06 PM
dirtgypsy dirtgypsy is offline
Member Number: 564
what size bearing in the rear trailing arms?
That is a killer looking chassis and very creative in the suspension mods!
Clint
Old 11-14-2009, 07:03 PM
Bird8oy's Avatar
Bird8oy Bird8oy is offline
I have a problem and they don't know what to call it...
Member Number: 9312
This thing rocks.... I want to try one of these also, prob the two seater though!
Old 11-30-2009, 06:19 AM
ThomasR's Avatar
Member Number: 3583
Clint
Thanks! They are 1150 Flange bearings. I think they are 1150...will measure today evening and reconfirm it.
Old 11-30-2009, 12:32 PM
ThomasR's Avatar
Member Number: 3583
Correction: The bearings are 1050x40mm
Got new Astute rear drive shafts. The fit perfect to the width from the Gearbox Joints to the swing arms! Rebuilt the Gear box with new parts and fitted a Tamiya M-Chassis tuned Motor. This motor has an about 1,5cm shorter housing, so it does not lug out of the gearbox.
Just a quick Mockup. This is final position as the gearbox will sit.
Old 11-30-2009, 03:04 PM
lemecanodejante's Avatar
Scale is good!
Member Number: 1144
great project and good package
Old 11-30-2009, 05:13 PM
caprinut's Avatar
caprinut caprinut is offline
Member Number: 448
x2
R.I.P Ole (8th Oct 2012)
Old 12-28-2009, 08:43 AM
SCRT Pilot's Avatar
SCRT Pilot SCRT Pilot is offline
All bad things come to those who haste
Member Number: 10251
Are those trailing arms still available? I'm looking for something similar for my next project (mounting blocks, hinge pins included) having them made is too expensive and I even don't know whether I designed them right or wrong.
Do they have camber or are the left and right arms the same? Do you think a Traxxas drive shaft will fit?
Thanks,
Old 01-03-2010, 02:38 PM
ThomasR's Avatar
Member Number: 3583
Yes. Those trailing arms are still sold on ebay. Search for Kyosho Scorpion. They are not expensice. The mounting parts are difficult to find. But you could use everything that works. Left and right arms are same. The only thing is that they describe a circle when trailing, so the outside mounting shall be higher then the inner. I can take some pictures and measurement if you want. Traxxas I have no idear. I know what Tamiya part will fit.
