Old 04-07-2010, 06:44 AM
ThomasR's Avatar
ThomasR ThomasR is offline
Member Number: 3583
OK, I understand. Such large diameter wheels cannot fit.You need 1.9 or better 1.55 wheels/tires from RC4WD. If you want use these wheels, you'd better look for another solution. Use Tamiya DF-03 rear lower arms with knuckle might help.
  #62
Old 04-19-2010, 12:44 AM
ThomasR's Avatar
Member Number: 3583
A little update to keep the story ongoing.
Made alot of thoughts last weeks about the right suspension choice. Finally I found the best solution for this project. By chance I stumbled across a picture of upgrade aluminum DF03 lower arms and I bought a set on ebay. Well...they are perfect for my build. Exactly what I need and they are easy to mount without making further changes to the chassis. The stance is just perfect and the arms are quite filigrane which gives just the right look. I Will go for same wishbone setup for the rear. Found a real Sand Rail that has same wishbone setup at rear. So I will not break with anything real.
So far I just fixed the front arms and flexed off the strange front shock stay. I will fab my own as needed later. These shock mounts on the pictures are just temporare brackets. Hope you like it.
And this is the real one with wishbone setup at rear instad of the usual trailing arm.
Old 04-19-2010, 03:12 AM
Spoon37's Avatar
Spoon37 Spoon37 is offline
Member Number: 16
looks slick!
Old 04-19-2010, 04:58 AM
THE_JOKER
Posts: n/a
Member Number:
Pro work!! love it!
Old 04-19-2010, 09:55 AM
Waterboy's Avatar
Waterboy Waterboy is offline
Member Number: 10658
B/S/T Feedback: (9)
More please! Looks amazing!!
W@T3R8oY wUz H3R3! Well, im Broke MoFo #89!! Eat that Lauer!!
Im suffering from RC addiction. Oh it hurts so good.
Old 04-20-2010, 12:32 AM
ThomasR's Avatar
Member Number: 3583
More progress soon...
Old 04-20-2010, 08:15 AM
Waterboy's Avatar
B/S/T Feedback: (9)
Yesssssssss...
Old 04-23-2010, 11:48 AM
Roady's Avatar
Roady Roady is offline
Member Number: 11162
Wow, that looks so good, cant wait for more
Old 04-26-2010, 01:25 PM
ThomasR's Avatar
Member Number: 3583
Default update front suspension
Got some new parts today and I could not let my hands off it. So I started cutting off the original front lower wishbone and upper tie rod mounting points with an angle grinder and tested the new front suspension mount. Perfect fit.
Still have to drill holes to tighten it to the chassis. Did not have enough time today to do that.
Old 04-26-2010, 03:10 PM
RandallCM's Avatar
RandallCM RandallCM is offline
Lurk
Member Number: 6877
She's turnin out right clean sir.
Old 05-02-2010, 02:35 PM
ThomasR's Avatar
Member Number: 3583
Thanks for the nice words!
Got the front suspension mounted to the frame. Feels tough and the damper/spring rate is just perfect. Shocks working very smooth and soft.
Made also a short mockup to see how the motor, gearbox and rear suspension look together. V8 will be changed later. This setup will be quite the final I guess.
Old 05-02-2010, 06:11 PM
backwoodsoffroad's Avatar
backwoodsoffroad backwoodsoffroad is offline
buyer of junk and scrap....otherwise known as el-cheapo
Member Number: 10089
looking good :thumbsup:
Old 05-03-2010, 02:18 AM
Banana's Avatar
Banana Banana is offline
Member Number: 9159
WOW, it looks Great!!
I Like your job
Chassis is more beautiful without shock towers in front, it looks cleaner
Where are those beautiful rims from????
Old 05-03-2010, 05:21 AM
ThomasR's Avatar
Member Number: 3583
Indeed. I did not like the shock towers either.
The rims are from RC-Channel and are available in 0 and +5 mm offset.
Old 05-03-2010, 11:48 AM
bonards29's Avatar
bonards29 bonards29 is offline
Member Number: 4236
B/S/T Feedback: (14)
that looks so sick man. the engine set up and suspension looks so real!
