Old 06-12-2016, 10:21 AM
Junkyard Stance's Avatar
Junkyard Obsessive
Member Number: 24499
Wow...! Serious drool happening here...
Awesome!
Cheers dude,,,
  #62
Old 06-12-2016, 10:29 AM
rustneversleeps rustneversleeps is offline
Member Number: 23519
Originally Posted by Junkyard Stance View Post
Hi rustneversleeps, Thanks !
When I've opened my Shapeways shop, you will be able to order the custom parts, they get printed, and are sent direct to you.
When the shop is open, I will post here first !
Ok sounds good...
Old 06-12-2016, 12:47 PM
lilsami87's Avatar
lilsami87 lilsami87 is offline
Member Number: 15145
Man this is just gettin cooler!!!
$hit happens
Old 06-12-2016, 02:12 PM
duellym's Avatar
duellym duellym is offline
Do a burnout!
Member Number: 22160
this thing is awesome. how well do you think the parts are going to stand up if you get into an "accident"?
When the road ends life begins.
BAM!
Old 06-13-2016, 10:27 AM
Junkyard Obsessive
Thanks for checking in with the build, very glad you're enjoying what you see !
Old 06-13-2016, 10:33 AM
Junkyard Obsessive
Hi duellym, thanks for you reply - I think it's more of a "when" than an "if"
The cast metal parts - Wing Mirrors and Nerf Bars are very robust and weighty - I think they will stand up well
The nylon parts should be a least as strong as the original ABS shell - they are somewhat more flexible and less brittle
I'll post here with my first damage report !
Old 06-13-2016, 11:03 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Sump Guard
Next up, some protection from the bottom of the flat six engine, the Sump Guard - Here is my design
And the printed nylon part, in primer - Though I may well look at a cast metal material for this, going forward
offered up to the engine assembly
The holes in the Sump Guard and Engine Block were enlarged to suit the hardware
And fitted in place
Here's the upturned engine, Sump Guard on
and the bottom/rear view
Old 06-13-2016, 11:26 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Cooling Fan
The Cooling Fan slots right into the Fan Cowling
Here's the 3D printed part, in primer -
The center hole was enlarged with a 1.6mm bit, to clear the M1.6 cap head screw that will eventually fix the Cooling Fan in place
For now, it will just sit in place
while I fit all the other engine ancillaries, the Alternator, Distributor, Timing Belts and Belt Guard
The Engine, ready for it's ignition system and timing parts
Old 06-17-2016, 01:47 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Distributor
The ancillary engine parts really tested the nylon material at it's smallest print size - I used .7mm minimum wall thickness to generate the most "scale" engine details possible ( for me , anyway )
First up, the Distributor
and the first test print -
The Distributor fits on the left side of the Engine Cowling, the three pilot holes in the Engine Cowling needed enlarging to suit the M1.6, 6mm hardware (with a 1.2mm bit)
And the holes in the Distributor were very carefully enlarged with a 1.6mm bit, to just clear the screw
Before
and after
Ready for fitting
The Distributor secured in place
and on the the growing flat six engine
Old 06-17-2016, 01:53 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Alternator
The Alternator fits on the opposite side of the Engine Cowling to the Distributor
The test 3D print
All the holes in the Alternator were enlarged in the same way as the Distributor
And the Engine Cowling was prepared to fit the part
The Alternator, fitted in place
And with the Distributor
Old 06-17-2016, 06:20 AM
Ho-leeee crap.....dude ... This is a whole new level of OCD ...!!! I love it!! Are you drawing each individual part yourself? That must have taken ages to do..... Awesome!
Old 06-18-2016, 04:10 AM
Junkyard Obsessive
Hi Trini2DBone - Thanks for checking back ! - glad you approve
I am indeed drawing, and modeling, all the parts myself - My technique for developing parts starts in quite an old school way - My favorite tools
enable detailed measurement taking
This allowed me to build a reasonably accurate model of the shell, which I refined as I made parts that didn't fit !
Once the the model of the body shell became more accurate, the task became somewhat easier and quicker - I used to have a long commute to my day job, 10 hours a week on a train where I was able to build my Scorcher parts on a lap-top
Fitting the custom parts to each other is much easier than fitting a custom part to the curved surfaces of the Sand Scorcher. Most of the engine parts fit to each other, so most were good to go on the first attempt. The revised rear cage - as it is the interface part between my engine and the stock chassis - took about 4 prints to get a good fit, then a few more as I tweaked the design and the angle it sits at
The build I'm showing now is the result of about 8 months of commuting !
Old 06-18-2016, 10:03 AM
I have never really been a big fan of the beetle buggies, but this is really changing that....will these parts eventually be available for sale on shapeways?
Old 06-18-2016, 07:24 PM
walter walter is offline
Member Number: 15933
very nice work
Old 06-19-2016, 11:55 AM
mibaxx's Avatar
mibaxx mibaxx is offline
DHARMA Engineer
Member Number: 11884
W O W !! That's...amazing! I'm...speachless...really.
If you ever plan to sell this great peace of modeling, please think on me.
