Old 06-26-2016, 08:47 AM
Junkyard Stance's Avatar
Junkyard Stance Junkyard Stance is offline
Junkyard Obsessive
Member Number: 24499
Default Junkyard Stance Sand Scorcher, Final Rear Cage
So, my designs for the rear Engine Cage to house and protect the engine changed quite a bit as the engine itself evolved
My final design removed the rear tabs for the aerial fixing, for a more scale look
The engine has to be fitted into the Engine Cage at this point, as once the twin Turbo Exhaust is fitted, wiggling the engine into the cage became an issue
I planned four mounting points for the Porsche engine, two on the underside, and two on the inner facing side - but in the end, only used the two on the underside
The flat six, in place in the Engine Cage
I was finally happy with the fit and look of my enlarger rear Engine Cage.
For added protection, the part was designed to meet the material tolerances for Shapeways cast metal.
So bring on the metal version -
  #92
Old 06-26-2016, 08:57 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Twin Turbo Exhaust
The final parts for my Porsche inspired, flat six, air-cooled power unit for the Junkyard Stance Sand Scorcher is its Twin Turbo Exhaust system
For each side, there is a three part assembly - mainly for ease of painting - consisting of the Turbo Exhaust itself
The Air Filter Mesh
And the Filter Cap
Here are the parts for one side, in primer
The fixing point to join them together needed enlarging to suit the m1.6 hardware
And fitted together
And here are both sides, ready for fitting
Old 06-26-2016, 02:48 PM
lilsami87's Avatar
lilsami87 lilsami87 is offline
Member Number: 15145
Top notch as always!
$hit happens
Old 06-27-2016, 12:31 PM
it's like a work of art
Old 06-28-2016, 06:50 AM
This is so fantastic.
Great Build.
Love all the new personal Looks and Modifications.
Old 06-28-2016, 10:45 AM
Junkyard Obsessive
Thanks lilsami87!
Old 06-28-2016, 10:46 AM
Junkyard Obsessive
You are too kind ! thanks for checking back in with the build
Old 06-28-2016, 10:47 AM
Junkyard Obsessive
Great Build.
Hi 2Beers ! glad you're enjoying the build - plenty more to come !
Old 06-28-2016, 11:01 AM
Junkyard Obsessive
The pilot holes in the exhaust manifold - part of the Engine Block - are intended to take a 5mm screw from each side
These need enlarging to clear the m1.6 cap head I'm using
The corresponding male part on the Turbo Exhaust - the inlet pipe for the turbo - has a pilot hole to accept the screws. This was enlarged with a 1.2mm bit to give a good bite
Turbochargers forced feed air into Induction System, so the pilot hole in chucky feed tube to the inter-cooler was also enlarged with the same 1.2mm bit
And back to the 1.6mm bit to enlarge the remaining two holes in the turbo outlet
Here's the joint at the exhaust manifold, screws in place
And the where the turbo output meets the inlet for the inter-cooler
Old 06-28-2016, 11:06 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Air-cooled flat six, twin turbo Porsche engine
Here's a few of the complete Air-cooled flat six, twin turbo Porsche engine, in primer
Old 07-04-2016, 09:28 AM
vonmarshall's Avatar
vonmarshall vonmarshall is offline
Member Number: 15135
Well that is just perfect. What an amazing job you have done. My Scorcher needs one of them!
Old 07-04-2016, 10:32 AM
Junkyard Obsessive
Thanks vonmarshall ! Glad you're enjoying the build - If you going to put an engine in the back of a Scorcher, it may as well be a flat six Porsche turbo
I will be making the engine parts available, in due course - I'd love to see what other builders could do with it !
Old 07-04-2016, 10:39 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Gear Casing
A quick aside before I mount that Porsche engine on the Sand Scorcher - I decided that a matt black gearbox casing would help show of the flat six to best effect - So I stripped that sucker down
Masked off the outside of the transparent covers
A few coats of matt black on the inside
And when dry, with the masking tape removed
And the metal casing after primer, and two coats of black
And all the parts,
Were ready to be reassembled
Old 07-04-2016, 10:48 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Fitting the Porsche Engine
Mounting the Porsche engine assembly to the chassis was fairly straight forward as my revised rear cage - although both wider and longer - uses the standard fixing points and original Tamiya hardware.
I revised design of the cage several times before getting the angle it sits at just right, dead flat with the chassis and it looked too low at the very rear - it tilts upwards by about two degrees
Here's a few of the primed engine, mounted on the chassis
Old 07-04-2016, 11:07 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, sit back, take stock
It's that time again - sit back and take stock of the work so far - particularly as the next step will see this Sand Scorcher stripped down and given the junkyard treatment
So, does the rear end of my Scorcher
now hold its own with the front ?
I will let you guys be the judge
There's only one small - but important - addition to the front end, and then it's off to the junkyard
I've now put a few of my parts on Shapeways for sale, should anyone be interested.
It will take me a little while to include all the parts you've seen here in this build, so please be patient, and check back from time to time to see what's new.
Here's the link:
http://www.shapeways.com/shops/junkyard_stance
