Old 06-06-2016, 07:55 PM
lilsami87's Avatar
lilsami87 lilsami87 is offline
Member Number: 15145
Wow, thats exactly what it was missing! This thing keeps gettin better. Definitely goin to need to build one now!!!keep it up man!
$hit happens
Old 06-08-2016, 12:27 PM
Junkyard Stance's Avatar
Junkyard Obsessive
Member Number: 24499
Hey lilsami87 ! - Glad you're enjoying the build - plenty more to come !
Old 06-08-2016, 12:42 PM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Flat six engine block
The heart of any engine has to be the block, in this case a flat six, air-cooled unit that takes inspiration from the boxer block used in the Porsche 911 for decades
Here's the first 3D printing of the Engine Block - the minimum wall thickness on this material is .7mm, I tried to match that minimum on the cooling fins.
On the upper facing sides you can see fixing holes for the Fan Cowling, and locating holes for the Induction System:
On the underside I included the exhaust manifold with the Engine Block, but I have planned a custom Sump Guard, probably in a cast metal:
Here's the Engine Block in primer:
Here are the two fixing holes for the next part - the Fan Cowling - accessible through the sump hole:
They need enlarging to suit the chosen hardware -
for an M1.6 screw, I enlarge with a 1.2mm bit
for an M2 screw, I enlarge with a 1.6mm bit
Here's the fixing screw from the outside, this screws in to the next component, the Fan Cowling
Old 06-08-2016, 12:58 PM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Fan Cowling
To keep that Engine Block cooled, most air-cooled engines rely on a crank driven fan that draws air across the fins on the Engine Block.
Here's my custom design for my flat six Fan Cowling that both supports the fan itself, and directs air flow over the Engine Block
And the printed prototype,
and from the front
Here's the same part in primer, the center hole is for mounting the Fan and Timing Belt parts
On the other side, you can see the fixing hole for the next part, the Induction System
Down each side of the Fan Cowling, the are three locating holes - six, one for each cylinder - that fits the bottom of the Induction System
From above:
Here's the Engine Block and the Fan Cowling, on the underside you can see its fixing holes
These needed the customary enlarging for my chosen M2, 8mm hardware
From inside the Engine Block, here are the tighten button head screws securing the Fan Cowling
Old 06-08-2016, 01:00 PM
Junkyard Obsessive
Here's a few of the first two engine parts, fitted together:
Old 06-08-2016, 04:35 PM
walter walter is offline
Member Number: 15933
this is very cool
Old 06-09-2016, 04:52 AM
Junkyard Obsessive
Originally Posted by walter View Post
this is very cool
Thanks walter ! - check back again sometime, there's some cool updates coming
Old 06-10-2016, 01:14 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, the Induction System
Sitting on top of the Engine Cowling, the Induction System receives the hot, pressurized air from the Turbo Exhaust, directs it through the Inter-cooler Mesh and then feeds it into to the cylinders via the carburetors or injection system.
Fuel and Nitrous is added, and the mix ignited !
My forced air Induction System is made from three separate parts ( mainly for ease of painting - though more would have been easier ! )
The Induction System
The Inter-cooler Mesh
And the Inter-cooler Lid
As usual, I enlarged the pilot holes in the printed pieces - with a 1.2mm bit for the Induction System
And with a 1.6mm bit in the Inter-cooler Lid ( the screws shouldn't bite into this part)
Here are the three parts, ready to fit together, using four 6mm M1.6 shinny cap heads
And a close up of the Inter-cooler Mesh, sandwiched between the Induction System and the Inter-cooler Lid
On the underside, in amongst the fuel and nitrous pipes, you can see the fixing hole for the Induction System
This was enlarged with a 1.2mm bit, to receive an M1.6 16mm screw
Old 06-10-2016, 01:29 AM
Junkyard Obsessive
In the Fan Cowling, there is a buried fixing hole that needs enlarging - as I was using an M1.6 screw, and didn't want it to bite into this part - I enlarge with the same size drill bit, 1.6mm
the fixing hole is access through where the Cooling Fan will eventually sit
Here it is, with the screw in place
and from the outside - when the Induction System is in place, this will hold it tight to the Fan Cowling and Engine Block
Here's the flat six engine in progress
From round the back ( or front, depending on your perspective on rear engined cars ! ) - I've tried to sculpt the rear of the assemble to fit tight to the stock motor/gear casing
I was keen to build and entire engine model, not just a "facing" that surrounds the stock parts, even if that means it sticks out a bit too far
A few more of my work-in-progress Junkyard Stance twin turbo Porsche flat six engine
Old 06-10-2016, 06:55 PM
nice job looks very good
Old 06-12-2016, 09:50 AM
rustneversleeps rustneversleeps is offline
Member Number: 23519
Thumbs up
very nice.... do i just go to shapeway to get these parts...
Old 06-12-2016, 10:32 AM
Junkyard Obsessive
Cheers walter, nice to have feedback !
Old 06-12-2016, 10:35 AM
Junkyard Obsessive
Hi rustneversleeps, Thanks !
When I've opened my Shapeways shop, you will be able to order the custom parts, they get printed, and are sent direct to you.
When the shop is open, I will post here first !
Old 06-12-2016, 10:47 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Porsche Cam Covers
Next up, some Cam Covers - as my flat six engine design is loosely based on the 911 unit, I descided to go for some Porsche embossed Cam Covers - my designs:
Here's the white nylon printed part
Eventually, I may go for one of the higher res materials, but for this first fitting, all the engine parts I'm testing, I've had printed in the most economical material, the "Strong and Flexible" white nylon
In primer
The usual enlarging of the printed pilot holes
to accept the M2 button caps I'm using
The Cam Covers, fitting the the Engine Block
I'm pleased with the fit
The growing boxer engine
Old 06-12-2016, 11:03 AM
Trini2DBone Trini2DBone is online now
Wow...! Serious drool happening here...
Awesome!
