Talk among yourselves!
Old 01-18-2013, 06:15 PM
Also going to have to re-work the hub-carrier position on the suspension arms. The rotor disc actually moves the wheel out by almost 3 mms putting them just beyond the fender lip. So gonna take the front suspension apart and re-drill the hub carrier position inwards about 3 mms. Will also have to shorten the link rods etc.
Once this is complete, I will continue with the disc brake install
  #62
Old 01-21-2013, 12:00 AM
kungpow's Avatar
kungpow kungpow is offline
Member Number: 3157
Hey there kungpow, will definitely have some kind of video when it's done!
Will also look into the tq3 as well. Is the 3rd channel progressive or is it basically on /off? Never used one of those before.....
Ya the tq3 is a on off 2 position switch you can mod it to use a potentiometer but, that would probably be hard to make work comfortably.
Old 01-21-2013, 06:39 AM
Thanks for the heads up ! Yea, will probably start looking out for a decent but inexpensive stick radio...
Old 01-23-2013, 09:57 PM
Another update.....!
I re-worked the front suspension moving the hub carriers inwards about 3mms. The wheels tuck nicely now with the rotors on!
Old 01-23-2013, 10:04 PM
Also got the calipers installed!
Left side installed...
And then I remembered to take some pics while installing the right side...
Before installing the caliper..
Caliper and caliper mount for the motorcycle ...
Old 01-23-2013, 10:10 PM
Modified caliper mount with caliper attached
Assembly bonded to hub...
Old 01-23-2013, 10:15 PM
Last few for tonight....
The next step will be to figure out where to place the micro servo for the brakes, as the brake cables that came with the kit are pretty short...
Old 01-23-2013, 10:23 PM
Ohh forgot to add...I used DevCon Plastic Welder to make the bond...freaking thing hardened up like concrete! I would be very surprised if it should come loose! Ha!
Old 01-26-2013, 10:49 PM
Hey guys....need some assistance...
The cables that came with the brake kit is too short by about 2 inches.
Does anyone know where I can get a similar cable about 8-10 inches in length ?
The cable itself (inner piece) is .5 mm thick ( measured with my caliper). This piece moves freely in the housing or sheath.
This is the clearest pic I could find of the cable, as my camera doesn't do close up pics very well.
Old 01-26-2013, 11:07 PM
klampykixx's Avatar
Where did I go?
Member Number: 13899
could you not solder it to some speaker wire or similar?
Old 01-26-2013, 11:12 PM
Hey there Klampy, really haven't thought about doing something like that...not even sure if that will work....it's very similar to regular bicycle brake cables...
Old 01-27-2013, 01:40 AM
Honger's Avatar
Honger Honger is offline
Member Number: 12391
Just caught this thread... the brakes are such an innovative idea. I'm excited to see if you can get them working.
As far as longer brake cable, how about some of the braided wire that comes spooled on the 3racing winches?
Old 01-27-2013, 06:32 AM
SPEEDWHEELS's Avatar
SPEEDWHEELS SPEEDWHEELS is offline
Member Number: 19544
Wow bud that brake convention looks insane. Keep it up this car is going to be insane.
Old 01-27-2013, 10:08 AM
Hey there Honger! Thanks for the kind words!
I believe that they will work. The front wheels are free wheeling (no diffs etc) and if I manually pull on the caliper cam, the wheels lock up! So with the right cable it should work.
Not sure if the winch cable would work as the system will require a somewhat stiff cable that will push as well as pull in order for the caliper to release the rotor !
Old 01-27-2013, 10:13 AM
Hey thanks Speed! Yeah I was really surprised as well how it's turning out! Almost seems like its developing on its own to me as none of this was actually planned! Just trying to overcome the obstacles as I encounter them! Ha!
