Old 03-04-2017, 06:31 PM
bluedually's Avatar
yes I can tow a house
Member Number: 12594
Test fit the steering servo and the Traxxas transmission. I want to keep the motors up front so they get plenty of air.
Transmissions by Gordon Latimer, on Flickr
Test fit the transmissions, will have good ground clearance and shallow drive shaft angles.
Mounting HPI trans by Gordon Latimer, on Flickr
Old 03-04-2017, 06:40 PM
bluedually's Avatar
Old 03-05-2017, 10:23 AM
350TacoZilla's Avatar
Member Number: 2402
nice you staying with leaf springs up front and coilovers in back or is rear getting the leaf spring treatment too?
Old 03-05-2017, 11:11 AM
bluedually's Avatar
4 link and coils in the rear... Its sort of scale since they are leaf up front and air ride out back, at least the few I have seen.
Old 03-11-2017, 10:12 PM
bluedually's Avatar
Got started on the sub frame for the HPI trans and what the rear axle links will mount up too. Also left some material in front of the trans incase I switch to 4 link in the front or need to run traction bars to keep axle wrap under control.
Old 05-22-2017, 08:26 PM
bluedually's Avatar
Wasn't happy with the rails I had, so built new ones. Video here
Old 05-22-2017, 08:41 PM
bluedually's Avatar
Got the HPI trans mounted up. With the long drive shaft I could tuck it up in the frame a little better.
Of all the screws I have, I don't have the right size to bolt the Traxxas unit in
Old 05-24-2017, 09:05 PM
bluedually's Avatar
Built the sub frame for the rear 4 link. Haven't bolted it in yet as I need to get the body mounted so I can set the wheel base. Hoping to get it sitting on springs at all 4 corners this weekend.
4 link sub frame by Gordon Latimer, on Flickr
100_0277 by Gordon Latimer, on Flickr
Old 05-25-2017, 09:27 PM
bluedually's Avatar
Tinkered with some body mounts, they need more tinkering. Did figure out a solution for the much needed carrier bearing. This thing is so long, it will have to have 2 rear drive shafts. Just need to fab up something to keep the steering knuckle turned carrier bearing from pivoting and it will be good to go.
Old 05-27-2017, 10:52 PM
bluedually's Avatar
First plan for the traxxas transmission mounts wasn't going to work, but figured out something different. Its getting closer to being a roller.
Old 05-28-2017, 06:55 PM
bluedually's Avatar
Rear cab mount done and rear axle and 4 link bolted to the frame. Those 5 inch tires look kinda small lol.
Old 05-28-2017, 10:45 PM
bluedually's Avatar
Another build video
Old 05-29-2017, 08:31 PM
bluedually's Avatar
Suspension complete!!!! The truck has springs at all four corners.
springs by Gordon Latimer, on Flickr
Old 06-17-2017, 06:01 PM
bluedually's Avatar
Cab mounted and a cutting board electronics tray done.
And a Losi Mini T the CXT bed, just cause.
Losi Mini T by Gordon Latimer, on Flickr
Old 06-24-2017, 04:49 PM
bluedually's Avatar
Tires and wheels showed up. I dig the black HPI WheelyKing rims... but I had ordered them for the crawler/basher. So the tires aren't glued. 5.98" tall 2.2 JConcepts Scorpios, the right: height, width, tread pattern that I have been looking for. I am freakin stoked.
100_0396_zpshzgh3fp9 by Gordon Latimer, on Flickr
100_0398_zpsbtz8k62o by Gordon Latimer, on Flickr
