Talk among yourselves! |
#16
![]() Quote:
Lol...thanks 2Beers! Still a ways to go before I get there...one of the big issue will be the front cross member that also functions as the engine mount and has the lower suspension arms attached to it... ![]() ![]() |
Sponsored Links |
![]() Is there a type of glue that can bond the resin and make a strong bond, kind of like MEK melts the plastics and make them just like they are one piece?
Edit: sorry for a second I thought the subframe could be resin separately cast, but you would still have tue same issue for mounting the suspension components.. holes etc. Maybe if the resin is chuncky enough where the holes will be it will allow you bolting through? In doubt of strength you could add a steel plate on both sides of the resin chassis where it bolts so the bolts dont apply pressure directly at the hole? Last edited by Frederik : 02-10-2019 at 10:47 AM. |
#18
![]() Quote:
I will probably try thin brass sheeting / strips first, kind of like a strap around the chassis at the bolt point, but instead of drilling holes for bolts, I will try to solder brass nuts or tubing where the ends of the straps meet, and use those to bolt it together, kinda like cinching it closed (don’t really know the correct terminology) then maybe a brass cross member can be soldered to the strap...? You know me...it’s all experiments...lol! |
#19
![]() Will you drive it scale ?
Or are you thinking Brushless with 6 cell Lipo's piggy backed together for that water jumping skinny tire speed ? ahahaha I think honestly the casting would be more then plenty. It's not a traxxix go faster...hehehehe
Walking the fine line between Realistic scale and RC functionality.. Ron |
#20
![]() Lol...yeah...I think you are right! I do believe the casting will be enough!
#21
![]() Quote:
Just a note on the chassis shapes, if you're going for super scale I believe there is a difference between the ute and panel chassis. I can't for the life of me remember exactly what it was but fuzzy brain says it's around the kick up behind the cab. I have a sneaky thought in my head that the panel actually used a wagon chassis not a ute one but I might be wrong there. |
#22
![]() Quote:
#23
![]() It's cool, not like (build) I'm trying to (super) implant some (scale) kind of subliminal message (chassis) or nuffin..... Or am I??? Hehehe
I did a quick Google to jog my memory and stumbled on this site you might find useful. http://www.truckjungle.com/2012/02/0...ner-1971-1985/ The main difference between the models is the tonner chassis with it's extra bracing and longer wheel base, with the styleside ute and panel sharing a common shorter chassis without braces. These might be useful too, tonner chassis pics. ![]() ![]() ![]() |
#25
![]() Quote:
Hey 2red! Thanks for the link and the pics! And the info! Will have a read on it tomorrow, I did notice the brace on the tonner chassis when I was looking for pics on the internet! When I’m done with the HQ nose panels, I think I might start looking into doing the chassis...probably a mixture of styrene and brass fittings on the master, once that looks good enough, will move on to the molding... ![]() |
#26
![]() Quote:
#27
![]() Quote:
Hehehe.. all your scaling is super ![]() the wishbone front end would be really cool. They're not the most attractive construction in real life but then again they weren't exactly Rolls Royce either. |
#28
![]() Hey guys...here’s another
![]() ![]() Did a bunch of wet sanding, puttying, sanding, priming, sanding, puttying, sanding, priming, sanding........ ![]() ![]() ![]() ![]() Anywho, here’s a few pics...watcha think? I think it kinda looks like a HQ... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Trini2DBone : 06-27-2019 at 03:59 PM. |
#29
![]() Purdy....
Muscle car green. your chrome paint is still the bomb. Great up date.
#30
![]() Quote:
More to come soon! |
Thread Tools | |
Display Modes | |
