Old 02-09-2017, 01:19 AM
SteinHDan SteinHDan is offline
Member Number: 23571
Originally Posted by jakep53 View Post
Thankyou that is so awesome so do you use the CAD drawings to then send to your CNC machine and 3D printer? i have been watching the how to videos to try and figure out how to do this haha
Yes, correct. Fusion 360 can export both to the 3D printer and to the CNC mill.
For 3D printing, I just select the Body I want to print and right-click "Save as STL".
For CNC milling, I go to the CAM workspace in Fusion 360 and create all the different types of cuts there.
Here is a CAM tutorial video:
Best regards,
Stein :-)
  #137
Old 02-09-2017, 01:32 AM
jakep53 jakep53 is offline
Member Number: 25250
- https://www.youtube.com/watch?v=txmsxUPegAM
Best regards,
Stein :-)
thankyou im going to go through the videos and see what i can learn!! I am an apprentice diesel mechanic so I work on this type of stuff and i think it would be awesome to build a small scale version!!
Old 06-29-2018, 09:47 PM
Dippingrizz Dippingrizz is offline
Member Number: 26839
Hi Trackerman!
I bought it from a local shop. But you can buy it on Amazon:
- http://amzn.to/1W71CaA
Stein :-)
What is the name of the local shop I cant find the chain with the k1 attachments anywhere.
Old 06-30-2018, 03:04 AM
The name of the local shop is "FB Kjeder AS", their website is here: http://www.fb-kedjor.se/no/
Unless you are located in Norway, though, I think you will have more luck with the global services like Amazon and Ebay or rollerchains4less.com or similar. Just search for "k-1 roller chain".
One example result:
- https://www.ebay.com/itm/163026216785
Best regards,
Stein
Old 12-22-2018, 06:02 AM
redpiperbob redpiperbob is offline
Member Number: 27402
Hi Stein
I have just got started in the 1/14 model thing and have built a couple of trucks from kits . I was looking for something to widen my horizons and here it is . Thanks for all you time spent on this thread and thank you for the cad drawings. I am about to start ordering bit. Once again thanks.
Bob
Old 12-22-2018, 06:42 AM
My pleasure! :-)
Stein :-)
Old 12-26-2018, 12:58 AM
sandfarmer's Avatar
sandfarmer sandfarmer is offline
Farming for real but R/Cing for life!
Member Number: 18671
So stein what's the update? 2 yrs since Any progress report, did you finish it? Unreal work thus far, just amazing!
Old 01-18-2019, 03:57 PM
I found a use for it at my workplace doing promo work and I just finished it enough for that. Now it has been at my work for all this time and I'm thinking about retiring it and taking it home to do the final pieces of work (add lights etc).
Here are two recent pictures of it in it's current shape:
Stein :-)
Old 02-09-2019, 03:30 PM
fatroyce fatroyce is offline
Member Number: 27564
How powerful is the excavator ? can it dig like a hydraulic one ? I just registered because of this thread very awesome home built machine !!!!!
Old 06-22-2019, 12:45 AM
It is just as powerful as my hydraulic machines, and it digs real dirt.
Stein :-)
Old 06-22-2019, 01:07 AM
One of the things I have to fix, is the left track motor. After a truck transport from the other side of Norway, the back platform had been broken off on both sides and the track motor did not run. I think maybe it was attempted lifted in the plastic, it broke and the whole thing crashed to the ground. But I don't know exactly since I wasn't there. Anyways, it has to be fixed.
Heavy as it is and with all that force on the track tensioner, I actually had to make a little plan on how to go about it, almost like on a real machine. I put it on it's side and got to work. Luckily I had a replacement motor lying around:
Finally back in shape!
Stein :-)
Old 10-17-2019, 05:21 AM
Ali Ali is offline
Member Number: 28940
Hi;
There aren't upper frame and base plans on undercarriage_4 v192, If it is possible please email me upper frame and base plans.
Thanks a lot
Best regards;
Old 10-17-2019, 11:29 AM
Originally Posted by Ali View Post
Hi;
Thanks a lot
Best regards;
The v192 is one of the very early versions that did not have those components, correct. But download the v300 that you find on the previous page. That version has everything.
Best regards,
Stein
