Old 06-19-2016, 12:53 PM
Junkyard Stance's Avatar
Junkyard Obsessive
Member Number: 24499
I have never really been a big fan of the beetle buggies, but this is really changing that....will these parts eventually be available for sale on shapeways?
Hi Trini2DBone - A convert !, I guess anyone into their RC has to build a Sand Scorcher/Baja Bug at some point in their build career - this is mine
Once I'm a little further into the build I will be looking at setting up the Junkyard Stance Shapeways shop - I will post any news here first !
  #77
Old 06-19-2016, 12:54 PM
Junkyard Obsessive
Originally Posted by walter View Post
very nice work
Hi walter, very glad you like ! Thanks for checking back with the build
Old 06-19-2016, 01:01 PM
Junkyard Obsessive
Originally Posted by mibaxx View Post
W O W !! That's...amazing! I'm...speachless...really.
If you ever plan to sell this great peace of modeling, please think on me.
Thanks mibaxx - I am pleased you like my Porsche engine plans for my Sand Scorcher
Eventually, you will be able to order my custom engine (and other) parts through Shapeways Europe, they print the parts in the Netherlands and send direct to the customer. Check back with the build for more information in the near future
Old 06-19-2016, 01:14 PM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Ignition System
Now the Distributor and Alternator are in place, it's time to back track a few steps and consider the engine cabling and electrics
On the Fan Cowling, I included a set of grooves and clips to hold in place some 1mm "bell wire" - single core copper cable - for the ignition leads and earth cables
These were all enlarge carefully with a 1.2mm drill bit
as well as the seven holes in the Distributor cap
The start plan for the wiring was something like this
Feeding the wires through was fiddly and took a little time - I started with the wire too long at first, and then cut it down as I worked with it
Across the top of the Fan Cowling
And into the Distributor cap
At the Cam Cover ends, I used some black heat shrink for the spark plugs
Old 06-19-2016, 02:11 PM
mibaxx's Avatar
mibaxx mibaxx is offline
DHARMA Engineer
Member Number: 11884
Not only parts my friend. The whole scorcher you build here is what I want to have. I don't have a scorcher and till now no plans to build one. But if see this...maybe a dream will come true?
The other way, I'll repeat: If you plan to sell this fantastic buggy after finished, please think of me...really!
Old 06-19-2016, 02:25 PM
Junkyard Obsessive
Hi mibaxx - I understand ! - Many thanks for the complement ! Presently, I'm not planning to sell the buggy - but if I change my mind, I will let you know
Old 06-19-2016, 02:40 PM
Junkyard Obsessive
Next up, the three remaining ignition leads for the second bank of cylinders - these use a similar set of clips on the opposite side.
I'm also using the fixing points on the sides of the Fan Cowling for a pair of ground leads, in black
Again, the red bell wire was fed through the enlarged fixing points before cutting to size
From above, with the red ignition leads in place, and the black earth leads run down each side of the Fan Cowling
The earth leads tuck into the back of the Fan Cowling
One runs to the rear of the Alternator, fitting in next to the red live cable
and on the other side, the ground lead runs to the Distributor
And fits into the center of the six ignition leads
Not an entirely real ignition system - I left out the ignition coil/stater motor but I'm happy with the added detail it brings
Old 06-20-2016, 03:38 AM
vonmarshall's Avatar
vonmarshall vonmarshall is offline
Member Number: 15135
Oh my what an absolute materpiece. I am blown away by the work you are doing on this.
Will you be offering any of your parts via shapeways?
Old 06-20-2016, 09:43 AM
Junkyard Obsessive
Many thanks vonmarshall - I'm very glad you're enjoying the build
I will be making parts available through Shapeways soon, watch this space !
Old 06-20-2016, 09:52 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Timing gear
Now the engine has had the Induction System re-fitted,,,
,,,it's time to look at the timing gear and belts for driving the Cooling Fan and Alternator
First up, a back plate that acts as a belt and chain guard
Name:  03_Junkyard_Stance_Sand_Scorcher_nd_JY-S_SS_ArtWork_ENGINE-CHAIN-GUARD_onWhite_A1.jpg
Here's the 3D printed test part
And in primer
And mounted to that, the belts and chains that link up all the ancillary engine parts that are visible from the rear of the Sand Scorcher
This print had to use the minimum tolerances for the nylon material, and is quite delicate
And in primer
The lugs round each pilot hole in the Chain Guard
fit the holes ion the back of the Timing Gear
Old 06-20-2016, 10:01 AM
Junkyard Obsessive
Default Junkyard Stance Sand Scorcher, Timing Gear
The vertical belt of Timing Gear fits the Cooling Fan
All the pilot holes in the Timing Gear,
The Chain Guard
and Cooling Fan were enlarged to clear the M1.6 cap head screws I was using
Most of the fixing screws were either 6mm or 8mm, but the two center ones needed to be 16mm to fasten all the way into the Engine Block
The screws fitted, from the reverse side
and front the visible side
When included with the Cooling Fan and Chain Guard,
here is the reverse side
and the complete assembly, ready to fit to the flat six engine
Old 06-20-2016, 11:03 AM
mibaxx's Avatar
DHARMA Engineer
Awesome. Even a little bit better with every piece of 3D print, every screw and every great idea for this engine. Can't wait to see the motor in position.
Old 06-23-2016, 05:05 AM
Junkyard Obsessive
There are 11 pilot holes printed into in the Engine Block that needed enlarging to suit the chosen m1.6 hardware, I used a 1.2mm bit to give a good bite
And one in both the Fan Cowling, and Alternator
Here's the Timing Gear assembly, in place at the first test fit
And ready to go on the Porsche flat six, with the all the ignition leads fitted
I used mostly 8mm screws to fit the Timing Gear
With two 16mm screws for the center two fixing points
I'm pleased with the end results for the Timing Gear
Old 06-23-2016, 09:10 PM
rustneversleeps rustneversleeps is offline
Member Number: 23519
Looks Captain Fantastic man.....wish i had that in the back of my Scorcher..
Just a suggestion if it were my motor i would be putting scale 1.5 mm scale bolts.the one's pictured here are 2.5 but smaller are available in anodized or stainless...
Old 06-24-2016, 05:36 AM
Junkyard Obsessive
Hi RNS
Totally agree !, I have used some M2 versions of these as I put together the Scorcher on its final final fit - Check out the bottom of page 1 - tested on the Sun Visor - they look proper scale !
For the engine, the M1.6 versions only come in 4mm lengths ( from RC Bitz), and they are yet to offer a fitting "tool" for this size
Hopefully, I will be able to include them by the time I finish the build
Thanks for your continued interest !
