Old 03-30-2015, 05:03 PM
Suprachrgd82's Avatar
is such a jerk!!
Member Number: 1781
Originally Posted by olblueyez View Post
Thanks, started collecting last August and finished around Christmas.
One of the diff bearings was kinda tough but the trans plate seems to have forced it into place.
Same here. So much binding, I couldn't use an MIP diff. RB6 it was, and it works perfectly.
Assembling those shocks was a helluva job, huh?
Originally Posted by JatoTheRipper View Post
Which color paint are you guys using to match the yellow Kyosho plastic?
Tower Hobbies recommends Tamiya PS-6. It matches pretty close, but not perfectly.
http://www3.towerhobbies.com/cgi-bin...&I=LXEMUG&P=ML
  #182
Old 03-30-2015, 06:51 PM
Member Number: 17899
Yeah it was but it was worth it. I have the instruction sheet that came with them if anyone one needs info or part numbers.
Fun Stuff Day 3
Old 03-30-2015, 10:13 PM
JatoTheRipper JatoTheRipper is offline
Member Number: 6821
Thank you. I read that PS-6 was an option. Some people like it while others didn't. I'll give it a shot. Thanks.
Old 03-31-2015, 09:51 PM
Member Number: 6821
Have any of you found a way to mount hex or pin drive wheels front and/or back?
Old 03-31-2015, 10:36 PM
is such a jerk!!
Member Number: 1781
http://www.scale4x4rc.org/forums/showthread.php?t=78577
Old 04-01-2015, 12:31 PM
Member Number: 6821
Rogue Element Components are typically very limited. I emailed him just to double check and these parts are no longer available.
There has to be another way.
Anybody else?
Old 04-01-2015, 01:56 PM
Arcocustom's Avatar
Member Number: 2344
dwyz250 on ebay used to make and sell a "KYOSHO REAR AXLES FOR 2.2 WHEELS SCORPION TURBO SCORPION TOMAHAWK BEETLE" 12mm hex adapter.
http://www.rc10talk.com/download/fil...5947&mode=view
http://www.rc10talk.com/download/fil...5948&mode=view
He also made adapters for RC10 wheels.
http://www.rc10talk.com/download/fil...7523&mode=view
You could try contacting him and see what he says.
http://www.ebay.ph/usr/dwyz250?_trksid=p2047675.l2559
Old 04-02-2015, 08:24 AM
Member Number: 6821
Thank you!
Old 04-08-2015, 12:35 AM
Any recommendations on battery capacity? "mAh"
Or maybe weight recommendations?
I can go 3300 or 5300 or 6000? Weight is the big penalty for more runtime. I just don't wanna buy a 3300 and wish for more run time.
http://www.thunderpowerrc.com/Produc...ity-70C-Series
Old 04-19-2015, 02:57 PM
Any point in gluing the rock hard front tires that came with the kit?
Old 04-19-2015, 03:21 PM
is such a jerk!!
Member Number: 1781
Not unless you want to hammer the car on the track.
Old 04-19-2015, 05:02 PM
That's what I figured. I have some softies on a second set and the black tie shelf set.
Old 04-19-2015, 07:13 PM
Yeesssshh,,... no starting point for the slipper clutch in the manual?
Any recommendations?
Just now its all the way tight minus 1/3rd turn. I don't have a clue if this is even close.
Old 04-19-2015, 11:43 PM
is such a jerk!!
Member Number: 1781
Not sure here either. Of the 3 Scorps I have, only one has been driven....by my daughter.....who thinks its fun to drive as slow as she can around the patio furniture...
Old 04-20-2015, 12:30 AM
I hope Kyosho put oil in the diff. makes me wanna open it up and look.
