Old 11-12-2013, 08:21 AM
danrkelly danrkelly is offline
Dan_in_UK
Member Number: 21177
Talking Rear shock stay variants.
Fantastic thread that I keep coming back to. I wonder can you help clear up the mystery of the rear shock stay on the Scorpion variants, mine has the short horns (sc-13 I think) for short shocks and see that some of your buggies have taller horns. Which is which as it were and what sort of shocks can I easily get which will fit the shorter type? I'm finding replacement 10mm clamps to be very expensive.
Cheers
Dan
London UK
Originally Posted by Honger View Post
Always enjoy your vintage threads... Very nice stuff.
  #92
Old 11-15-2013, 02:27 PM
Arcocustom's Avatar
Member Number: 2344
Originally Posted by Hcp22 View Post
BTW: Will you visit VONats in September 13th-15th at Bethel Racearena, Bethel, CT 06801
No. I did not. I bet it was pretty neat though. I read a little bit about it. Wish I could have participated in something like that.
Thank You.
Cheers
Dan
London UK
Thanks. Glad you like the thread.
This shock tower is custom made. It was made taller in order to fit the longer OT-43 Optima/Javelin/stinger shocks.
This car has PG-14 & PG-65 Gold Kyosho Gallop MKII shocks.
This car has a custom shock tower that is the same dimensions as the stock SC-13 part.
The Red shocks are AB-30 & AB-31 borrowed from a Kyosho Ultima/Assault/Advance.
Comparison photo (left to right) between the OT-43 Optima, PG-14 Gallop MKII, AB-30 Ultima, & PG-65 Gallop MKII
http://www.tamiyaclub.com/forum/uplo...1236126072.jpg
CRP#'s 1526 & 1527 Cox/Kyosho Adjustable Coil Over - fit the original shocks that came on the Scorpion & Tomahawk.
CRP#1536 Cox/Kyosho Rear Shock (adapter) Bracket - allows you to mount CB-38 Kyosho Land Jump shocks onto a Cox/Kyosho Scorpion.
Hope this post has been helpful.
Respectfully - Arco
Old 11-15-2013, 03:58 PM
Hcp22's Avatar
Hcp22 Hcp22 is offline
Member Number: 16219
I did the trip all the way from Sweden with this Tomahawk
Cheers Lars
Old 11-19-2013, 04:30 AM
Dan_in_UK
Talking
Wicked photos of the Tomahawk and thanks so much for the full run down of shock compatibility. Really helpful as is all this thread.
Old 11-20-2013, 05:38 AM
Dan_in_UK
Smile Scorpion is a Beetle
Hi there, what tires would fit the yellow plastic beetle rims front and rear. Are there off the shelf items that can be used? Thanks in advance.
By the way it turns out the trashed Scorpion I bought back in 1988 was probably a beetle looking at some of the bits I got with it including a tub cover, body mounts and tall roll bar that are all knocking around with the spares.
Thanks SMOKE-DOG. Glad you like it. The motor is definitely pretty sweet and it is period correct to boot. I have run it and it winds up pretty good.
I also am using an old Airtronics CX2P Caliber 2 ch. FM radio to control this ride.
I have been busy gathering parts to complete this buggy and here is what I have so far...
Nip SC-50 Kyosho Beetle roll bar and a reproduction front body post along with a reproduction rear body clip.
Reproduction Kyosho beetle decal sheet.
Reproduction SC-47 Radio Box Cover.
Reproduction Kyosho Beetle Driver Doll.
...and the final piece, a repro Kyosho Beetle body.
I trimmed the body but have yet to mount it on the chassis. I am still trying to decide how I should paint and decorate the thing. Box-Art or CUSTOM??
Old 11-20-2013, 04:17 PM
Arcocustom's Avatar
Member Number: 2344
The kit tires were originally released under the Kyosho, Cox, and Graupner names. These originals are very hard to find and don't come cheap. The ones on my Beetle are #SC-90 fronts and #SC-27 on the rear.
Any tire with a 1.6 in. (40mm) bead for the rear and any tire with a 1.9 in. (50mm) bead for the front will fit. Proline, CRP, and Duratrax made some aftermarket tires for the Kyosho size wheels back in the day.
Kyosho - (5 rib) Front Tire #SC-26
Kyosho - (Block Pattern) Rear Tire #SC-27
Early versions of these say "Good Year." The later versions had "Sand Super" on them.
Kyosho - (Spiked) Rear Tire #SC-84
Kyosho - (3 rib) front tire #SC-90
These only came with the words "Sand Super" on the sidewall.
Kyosho Option House - (A) pattern tread rubber Rear Tire #1873
These say "Dunlop" on the sidewall.
Kyosho Option House - patterned tread rubber Front Tire #1875
These say "Bridgestone" on the sidewall.
Kyosho Option House - #W-5072 Ultima Pro front tires
Kyosho Ultima - (3 rib) Front Tire #SC-26
These have "Bridgestone" & "Sand Super" on the side.
The new RC10 Classic tires may also fit as well but I have not tried them.
Team Associated RC10 Classic "Proline Edge" Front Tire - #6865
Team Associated RC10 Classic"Proline Champion" - #6815
Old 11-21-2013, 04:39 AM
Dan_in_UK
Smile Invaluable support from Arcocustom
You are beautifully thorough in your replies, absolutely invaluable information, what a star you are!
DK London UK
Old 11-21-2013, 05:29 AM
Hcp22's Avatar
Kyosho Option House - (B) spike pattern tread rubber Rear Tire #1874
These say "Sand Super" on the sidewall.
Worth to mention to is AYK, MRP and AJ’S/Twin-K tires.
Cheers Lars
Old 11-22-2013, 05:11 AM
Dan_in_UK
Thanks HPC22.
Will anyone comment on the likelyhood of the RC10 repros fitting the yellow Beetle hubs?
[IMG][/IMG]
What about these for the front?
Old 11-22-2013, 04:44 PM
Hcp22's Avatar
The rear will fit, I don't know about the fronts, but they should be 1.9". This Kyosho OT-30 will fit even if they are 1.6"
http://www.ebay.co.uk/itm/NIB-OPTIMA...item19d7e825a5
Cheers Lars
Old 12-11-2013, 05:34 AM
Dan_in_UK
Red face
Hey Lar, OT30's on the way but still not convinced about the SM25 (Sandmaster) I've seen, I think they're about 2" and worried they'll be loose. Seller not replying to my questions at the moment http://www.ebay.co.uk/itm/2910298932... 4.m1438.l2649
Old 12-12-2013, 01:36 AM
Hcp22's Avatar
Im not sure, but I think they are 2.1 and wont fit your 1.9 wheels. This will fit http://www.ebay.com/itm/FRONT-PIN-SP...#ht_495wt_1015
Cheers Lars
Old 12-12-2013, 11:27 AM
Dan_in_UK
Thanks Lars, I've been keen to get something from within Europe but looks like I'll be talking to Glenn at CRP again, he's a good guy.
Old 12-14-2013, 03:43 PM
Arcocustom's Avatar
Member Number: 2344
Back in the mid 80's, I had Tamiya tires and wheels mounted on my Kyosho Scorpion because they were better all-around tires when you wanted too take your Circuit 1000 Buggy to the racetrack. Pictured below are the Holiday Buggy rear & Rough Rider front tires along with all the extra hop-up parts that I used to recreate that old-school set-up.
Old 12-14-2013, 03:44 PM
Arcocustom's Avatar
Member Number: 2344
CRP
#4115 Front Wheel Adapters mount tamiya wheels to the front of Kyosho 2WD cars
#4115 Cox/Kyosho Tamiya Rear Axle Adaptors
#5138 WHEEL BOLTS Stainless Steel
RCH
#121-R Red anodized 1.5" Rear aluminum wheel halves
#210-R Red anodized 1.75" Front aluminum wheel halves
#251 Cox/Kyosho Scorpion Sidewinder Aluminum Rear Hubs
PRO-LINE
#200-F Rough Rider Replacement Front
#2506 1.5" rear chrome w/hardware fits Tamiya
TAMIYA
#5153 Holiday Buggy Spare Tire "REAR" with Wheel
#19805108 Tamiya Buggy Champ Rough Rider Fast Attack Vehicle Front Tire
