Old 04-11-2005, 09:40 PM
xxRyanTxx xxRyanTxx is offline
Member Number: 199
I'm not the most crafty person around but I figured I would have a go at building some new shock towers for my TL01. While wandering Bunnings, I found some 1mm plate with holes. The stuff isn't stainless, I found it in the bracket section. So can I drill the 1mm plate with a cordless drill or dremel style drill ? Or do i need to use a drill press ?
______________________
Cheers
Ryan
Old 04-11-2005, 11:15 PM
Pro-4x4's Avatar
Pro-4x4 Pro-4x4 is offline
Sheep Shagger - I suffer from anal glaucoma!
Member Number: 122
Should be no problem Ryan- make sure you use a punch so you don't slip of were you want the drill. Welcome to scale4x4. :chug:
"How can I soar like an Eagle.... when I am surrounded by Turkeys!"
Old 04-12-2005, 07:07 AM
Spoon37's Avatar
Spoon37 Spoon37 is offline
Member Number: 16
yeah a regular handheld drill will do it.... but the centre punch is vital as drills seem to skate around much easier on steels than stuff like alu or wood...
:banana:
Old 04-12-2005, 09:30 AM
toyranosaur's Avatar
Member Number: 128
1mm. anything seems a bit thinsy for shock towers?
Old 04-12-2005, 09:44 AM
Spoon37's Avatar
Member Number: 16
well I've been using 3mm thick alu for mine.... :blink:
steel is a tad tougher tho...I guess theres only one way to find out.... :lol:
:banana:
Old 04-14-2005, 12:53 AM
Member Number: 199
It has a bit of flex but 2 pieces of plate equals 2 mm. I'm gonna do shock towers last, other things need attention first like that silly battery holder. Will post pics once the first cut is done.
Cheers
Ryan
Old 04-17-2005, 05:05 PM
Maxxcrazy Maxxcrazy is offline
Member Number: 60
True, but it still won't be as strong as 2mm plate
Old 04-17-2005, 11:45 PM
Member Number: 199
Its only a TL01 :lol:
Cheers
Ryan
Old 04-18-2005, 01:50 AM
Rikpal's Avatar
Rikpal Rikpal is offline
Administrator - The forest dwelling drunken hobo. I'm ugly and stink
Member Number: 6
2,5 mm alluminium on a TL01
(the one and only crawling TL01 :lol: )
http://rikpal.golem100.com/rc/images...ech_img/06.jpg
http://rikpal.golem100.com/rc/images...ech_img/07.jpg
Rik - The Italian Guy
www.scalersandcrawlers.it - "THE" Italian Scalers and Crawlers Board - http://rikpal.golem100.com - [email protected]
If you have an apple and I have an apple and we exchange apples,then you and I will still each have one apple.
But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.
G.B.Shaw
Wannabe member of MtTABRA (More than Three Axles Big Rig Association)
