Go Back   Scale 4x4 R/C Forums > Other R/C and Misc > Static Models
Static Models This for you static display modelers. 1/24, 1/25, 1/18, 1/43, etc static display models, kits, pre-builts, whatever. If you got it, here's your forum.
Old 08-09-2016, 05:41 AM
jeffro jeffro is offline
Member Number: 8565
Default 1/16 "Big Daddy" AA Fuel Dragster
I usually have several things going at once. This is what I'm working on while I wait for paint and glues to dry on the Trike
Old 08-17-2016, 06:30 PM
Member Number: 8565
Now that the tiny trike is finished, its back to Big Daddy.
Old 08-20-2016, 08:40 PM
Bullitt's Avatar
Bullitt Bullitt is offline
Long Tall Texan
Member Number: 965
Very nice! I had one of these as well but I think it was a newer version. I remember that the rear tires had a very thin sidewall and would wrinkle easily and I had the hardest time gluing part#s 7,8,&9 together. That was a miserable experience especially when my mom decided that I needed to use the non-toxic glue (smelled like citrus) and wouldn't hold two magnets together. Fun times!
Harry
Old 08-27-2016, 01:03 PM
Member Number: 8565
Harry
Thank you Harry ! I believe you are correct, there seems to be 2 versions, maybe even 3 versions of the rear engine ones. The tires are very soft and thin walled, they melt down in the summer heat really well, and without looking to see what 7,8,an 9 are, I'm sure they were a P.I.T.A. It has so many tiny narrow, thin pieces, its hard not to break things.Good thing I'm much older now.
Mom trusted me with the good glue, but I struggled with taking time to scrape the chrome plating off to get a good glue joint. I convinced her the other was pointless...lol
I worked on it a little bit more then took a break, it was getting hard on my hands, so I switched to motorcycle model which I will try to post shortly in a new thread.
