Old 05-08-2008, 10:27 PM
2new4u 2new4u is offline
Member Number: 3358
Default what do u use
what do u use for the tube frames like the AX10 Scorpion tube frame
because i want to get in to making tube frame rock crawlers,sand rails stuff like that
1,what kinda of tube is it
2,where can i get the tubing
3,how do i bend the tube
4,where do i get a tube bender if there is one
5,how do i stick them together welder,solder what
5,what tube is good
please help me.
Old 05-09-2008, 12:38 AM
stone cold's Avatar
stone cold stone cold is offline
Member Number: 3482
1,what kinda of tube is it- steel brake line for autos
2,where can i get the tubing- automotive parts supply stores size 3/16" of an inch
3,how do i bend the tube-the atuo parts store should have hand benders as well
4,where do i get a tube bender if there is one-auto parts stores
5,how do i stick them together welder,solder what-mig welding on a low setting or brazeing
5,what tube is good-steel brake line is easy to get and work with
i hope this helps you out
Old 05-09-2008, 04:33 AM
For brazing you'll need a MAPP gas outfit. and brazing rod. Home Depot sells 'em.
Building tubers is easy and fun
