Old 06-10-2019, 07:19 PM
chewyscool's Avatar
chewyscool chewyscool is offline
LA4x4
Member Number: 14545
awesome!!
Lets see a recovery!
Old 06-19-2019, 01:35 PM
350TacoZilla's Avatar
350TacoZilla 350TacoZilla is offline
I need to think of something catchy here...
Member Number: 2402
Looks great man! It looks like it has a nice weight to it just in the still shots, how does it look when driving? Like nice "heavy lumber" to it and such? lol
Old 07-06-2019, 11:44 AM
Yeah. This pig is at 12 lbs so far.
And what’s a wrecker without some outriggers.
Copying a manual set from the m816
Showed up and inside a box beam
this whole thing slides out and then unscrews at the collar near the joint.
And mine in the stowed position
And out and down
Old 07-13-2019, 10:22 AM
Little more progress
Whipped up a towbar for vehicle recovery
Used the hc4 bed with homemade frame and axle and some BuddyL wheels to make a m105 trailer.
Also added a bench vise to the front bumper
A Jerry Can in the stock front step location
And a Hobart motor welder in the bed.
The Hobart is hiding an air pump which will get its own esc and run the smoke unit I’m working on.
Old 07-13-2019, 06:49 PM
danielk's Avatar
danielk danielk is offline
I build Lowriders
Member Number: 1386
Hell yes. I'm loving everything you're doing here.
"When you do things right, people wont be sure you've done anything at all."
Old 07-24-2019, 07:02 PM
Thanks!
And with everything going into this truck, the tires were going flat.
So I picked up some deuces wild foams from crawler innovations which are good for rigs over 8 lbs.
Changing the tires like a boss
So many wires.
Changed from my 3ch radio to a 6ch. The air pump is on ch3 which is a dial on this radio. It’s program mixed to ch2 so it speeds up with throttle input, but it’s also manually adjustable so I can make it chooch while parked, or idle up for winching.
The shift servo is ch5, and I found a receiver controlled switch for ch6 to run the smoke box so I can turn it off or on, uh remotely.
And I ran it around a little.
Old 07-24-2019, 09:07 PM
Nice job, the m35 is looking great! I'm loving all the details and functionality you're adding. Those outriggers are really cool.
I might redo the towbar you used on the chevy, for a more wrecker style lifting drawbar.
If you put a set of D-ring shackle mounts on the rear bumper, you could remake the K shaped bumper-lift tow bar with the pivot at rear. Then you'd be able to swap between shackles, the bar, or leave the eyes empty
I see the winch lines have the snatchblock hooks, are the top attached to the boom equipped with hooks also?
Have you seen the led beacons?
Old 07-25-2019, 11:06 AM
I get what you’re saying about the tow bar. My design was loosely based on the military’s towing setup. They use a tow bar that either has feet which attach to the front bumper shackle mounts for flat towing, or attaches to axle clamps that clamp to the front axle and a wiffle tree (spreader bar) attaches to the towed vehicle’s shackles and provides a center lift point for slung towing.
Yeah the original winch hooks are hanging from some m2 cross bolts I put under the upper pulley to make it a 2 part line (10 pounds) so I can unhook and have a one part line (5 pounds). Ideally I’d have a ring on top of the hook pulley so I could do a 3 part lift line (15 pounds). I might have to put a longer line on the winch for that. I already put double pulleys on the tip of each boom for 3 part line.
I have seen them, but I already have a 10 pack of 10mm yellow flashing LED’s prewired for 6v so that’s what I used.
They look about right based on the convoy lights on some of the 1:1 trucks I’ve played with.
Old 08-09-2019, 10:54 AM
Little more progress.
Got smoke out the stack and headlights are white now
This little piggy is 6.8kg!
Old 08-30-2019, 05:39 PM
RCJEEPBUILDER's Avatar
RCJEEPBUILDER RCJEEPBUILDER is offline
I love my wife!!!!
Member Number: 1672
Nice work Tim..
5 ton of fun
Old 09-04-2019, 08:59 PM
Thanks!
Did a Labor Day run with some people
Old 09-05-2019, 03:45 PM
Awesome tow rig! I especially like all the little do-dads you added for detail, very cool!
Old 09-05-2019, 06:02 PM
Looks like a beast, how'd it handle the trail?
Get to do any offroad recoveries?
Old 11-13-2019, 06:04 PM
Awesome looking rig
